Should my FTTC speed profile be adjusted?
- Re: Should my FTTC speed profile be adjusted?
08-09-2012 9:00 AM
It appears that I now have a 38Mbps Download and 5Mbps Upload profile.
I had a look at the BT Infinity checker results and they show my line is capable of 49.4Mb Download / 10.9MB Upload.
I've attached BT Speedtest and Infinity results.
08-09-2012 9:27 AM
08-09-2012 11:34 AM
speedtester.bt.com
speedtest.btwholesale.com
The helpful Plus Net staff looked at the post and told us to raise a ticket. We did this and found that the line had stuck on the 40/10 setting even though they had requested 80/20. Sounds like yours may have done the same.
WIthin around 24 hours of the ticket my inlaws now have a download speed of 71mbps so its well worth doing
![Cool Cool](/html/@852392E900DCC025F17256C42EA8F698/images/emoticons/cool.gif)
10-09-2012 12:25 PM
It appears that your profile is still on the 40/10 profile. I have placed an order to change this and you should see your speed increase be the end of tomorrow.
Please let me know if you have any further questions.
Chris
12-09-2012 9:13 AM
I wanted to get results which were similar to my previous recent performance but now things seem to be worse than before. I have attached two copies of results, both tests have been run using my normal setup with laptop ethernet connection and the Technicolour router and BT Modem connected to an extension. Extension cable from master socket is Cat 6.The first test run on 8th September and the second this morning.
I tried running tests with modem and router connected at master socket but the results were worse with a max download speed of approx 30Mb. I disconnected my extension phone and router wiring from the master socket but there was no difference, all my test results were slower at the master socket when run yesterday and this morning. I hadn't read the latest posts on this thread and was not aware that monitoring have been taking place to determine my max reliable speed.
12-09-2012 9:46 AM
I'd suggest raising a fault at http://faults.plus.net and complete the initial diagnostic questions, this will help make sure your setup is correct and working properly and raise this to us formally to investigate further.
If you need further help please let me know and I'll be happy to assist.
Chris
12-09-2012 7:27 PM
I have redone all my connections at master socket, router extension socket and phone extension socket. Speed tests using ethernet are similar at master socket and extension (a little better at extension) .
I also followed the trouble shooting guide from your link which led me to making a connection from laptop to LAN1 port on BT modem and attached test results below. A router reset did not make any noticeble difference. I don't appear to be getting any errors and more than 200 continuous pings to bbc.co.uk did not drop any packets.
Is this as good as I can expect, while the upload speed has improved the download speed is no better? My home is about 300 to 400 yards from the cabinet, at first fibre installation time we recorded 38Mbps. When running speed tests a few months ago I think download speeds were about 2Mbps better than now.
12-09-2012 10:55 PM
Let me know and I can leave well alone until a new profile has been established.
13-09-2012 11:59 AM
If you could complete the fault questions from the ticket you have opened then our faults team can look at getting this resolved for you.
If you need any help with this please let me know.
Chris
13-09-2012 5:21 PM
If you need any help please let me know.
Chris
