SNR etc with separate modem and router - How to view stats?
- SNR etc with separate modem and router - How to vi...
- « Previous
- 1
- 2
- Next »
Re: SNR etc with separate modem and router - How to view stats?
07-06-2014 8:22 PM
Quote from: shure Thanks, but as the Plusnet login is being handled by the Asus router now I don't understand how that would work? Wouldn't I have to change the Netgear to modem+router mode anyway to do that (and change from LLC to VC etc)? Or have I totally misunderstood?
My suggestion, if testing with a PC on port 2 of the Netgear works, does not involve taking it out of modem mode. Just try it if you've got a moment.
Message 16 of 22
(1,095 Views)
07-06-2014 8:28 PM
Quote from: zZz But from what I've read on Kitz forum, sadly I don't think anyone has got this combo working when the HG612 is specifically configured as an ADSL bridge modem. ie. it only seems to work in fibre (VDSL) mode from what I've googled.
Not true. This is precisely how I'm running my ADSL connection. Unlocked HG612 as ADSL modem connected to Plusnet TG582n running fibre router firmware. In other words exactly as a fibre connection but using ADSL. Rock solid and modem stats available on 192.168.1.1.
Message 17 of 22
(1,095 Views)
08-06-2014 10:10 AM
@pwatson: tried your suggestion, thanks, but couldn't connect to modem that way. I'm guessing that's because since there's no DHCP when it's in modem only mode it doesn't have an IP address anyway so there's no way to log into it? Come to think of it, I'd have to reset the modem anyway in order to get back into it? Scratching my head here!
@zZz: I don't quite understand this, sorry. I thought that putting the Asus into the DMZ would make port forwarding redundant? Or have I completely missed the plot?
Message 18 of 22
(1,095 Views)
09-06-2014 4:56 PM
Quote from: shure I thought that putting the Asus into the DMZ would make port forwarding redundant? Or have I completely missed the plot?
It was merely a suggestion if you were having difficulties getting remote login to the Asus to work.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Message 19 of 22
(1,095 Views)
09-06-2014 8:12 PM
@zZz: I'm sorry I didn't mean to sound dismissive. I thought I must have misunderstood something. I'm grateful for the help you've given so far
Message 20 of 22
(1,095 Views)
11-09-2014 1:25 PM
@pwatson
I know this is a really late reply but I've been travelling a LOT and haven't been able to sort this out. I just wanted to say your solution WORKED and I can now get router stats by fixing a static IP on my laptop and connecting via ethernet cable directly to an empty LAN port on the Netgear. Initially Windows tried to "repair" the wireless adapter, which is probably why I wasn't getting any joy. Once I disabled the wireless and set a static IP in the LAN connection it worked like a charm. Bit of a faff but at least I can see my stats now FWIW.
many, many thanks for your help
Message 21 of 22
(1,095 Views)
11-09-2014 1:35 PM
Glad it worked for you
Message 22 of 22
(1,095 Views)
- « Previous
- 1
- 2
- Next »
