SNR check
- SNR check
- « Previous
- 1
- 2
- Next »
Re: SNR check
03-10-2015 1:31 PM
Quote from: aesmith The test socket is on the back of the normal BT master socket, if you have your own telephone line then you should have this, surely?
Old type
http://i.imgur.com/hhfsXbV.jpg
Message 16 of 19
(412 Views)
Re: SNR check
03-10-2015 1:35 PM
Quote from: Townman What do you mean by "your stuff in the second filter"?
Telephone/Fax/PC Modem into 2nd filter, which plugs into 1st filter with router, which plugs into the bt socket
Message 17 of 19
(412 Views)
Re: SNR check
03-10-2015 3:19 PM
Wow - yes it is a master socket - ideally it and the wiring (looks non twisted pair) needs replacing-= used to be ok for a phone line but not good for broadband.
Pity there was not lots of noise on the phone an engineer would maybe have replaced it.
First thing to try as previously said would be one filter and router only and see if it improves.
Message 18 of 19
(412 Views)
Re: SNR check
03-10-2015 4:28 PM
I think it's good you don't need a phone fault - in my experience, Openreach don't replace old master sockets or bad wiring for voice faults. And why would they - as you said yourself, it's OK for a phone.
I would have thought an engineer sent to fix a slow broadband fault would replace it, BUT your speed may not be slow enough for it to be accepted as a slow speed fault. This is probably where it would help to be a new customer not getting your estimated speed.
Message 19 of 19
(412 Views)
- « Previous
- 1
- 2
- Next »
