Router placement
- Router placement
Router placement
24-10-2014 5:47 PM
Sorry if this seems stupidly basic! I've decided to try moving my ADSL router into another room. It is currently in the hallway at the front of the house. I get really poor reception in my top back room. However the other day I was moving stuff about and I happened to place my router in the kitchen. I then got fantastic speed throughout the house. I went from 2 - 3Mbps to the full 13 - 14 Mbps in my dead zone.
My plan is to place the router on top of my kitchen cupboards which are about in the middle of a open plan kitchen/living area. The only problem is the cable doesn't stretch to go up and through the wall. I when placed it originally in the kitchen the cable was long enough to reach round the corner to sit on the worktop. I have the opportunity to run the cable up behind the wall and through into the kitchen.
So I have two questions
1. anyone see any problems with my router being placed so high? It will sit approximately 25cm from the ceiling.
2. I thought any ADSL cable would do, but apparently not, I'm looking for a twisted pair? Can't seem to find one with that description. Also I've read inconsistent advice on if a 5m cable will slow my speeds down or not. Any advice?
I was just looking for something like this http://www.currys.co.uk/gbuk/computing-accessories/accessories-and-bags/power-cables/pc-cables/adven...
Re: Router placement
24-10-2014 5:58 PM
What you need is Cat5e
This is one link http://www.amazon.co.uk/s/ref=nb_sb_ss_c_0_8?url=search-alias%3Dcomputers&field-keywords=rj11%20cat5... and it is free delivery for the ones at the top
24-10-2014 6:03 PM
24-10-2014 9:48 PM
Edit: I bought at ADSL Nation and 10m cable, clips and connectors cost me five quid. They trade as Tandyonline now:
http://www.tandyonline.co.uk/catalogsearch/result/?q=cw1308
you'll also need to buy the disposable IDC tool which costs a bank-breaking 99p
26-10-2014 4:06 PM
26-10-2014 5:46 PM
Would it be easy or difficult?
26-10-2014 6:01 PM
Added. I should have said if you are going to make up your own cable you also need a tester to check the cable from end to end. You need tio check each pin in the plug has pierced the insulation and is making a good connection.
27-10-2014 9:49 AM
What I did was fix a new telephone socket to the wall of my study and connected that to the master socket in the hallway. Didn't have to connect any RJ11 ends. It gave me the flexibility of connecting a telephone to the same extension. Have to say I was daunted at the thought of opening the Master Socket but after being given excellent advice by people on this forum found that it was one of the easiest things I've ever done. There's nothing to it, really.
27-10-2014 10:17 AM
I was thinking of just getting this?
http://www.tandyonline.co.uk/high-speed-rj11-dsl-cable-5m.html
Any good?
27-10-2014 10:50 AM
Although Amazon/eBay might be cheaper.
NE
27-10-2014 11:35 AM
You are probably right that the ready-made RJ11 cables are not twisted pair. Maplins' description of CW1308 does not say it is twisted pair. If you want to make sure you are getting twisted pair you would be better following Oldjim's suggestion of Cat5e. Does it matter for a 5m cable?
Mounting a wireless router high up is a good idea and will usually give better coverage. Not so good is locating it in the kitchen, which may shorten its life.
27-10-2014 12:49 PM
Quote from: jrilton Hello,
It's twisted pair and the write up on their explanation page says it's the highest standard they have. At that price I'd say you have little to lose by going for it. I would avoid cheaper cable on e.g. Amazon or eBay unless you are sure of the quality and the fact it's twisted pair as a minimum. Whatever you do avoid the flat telephone cable many sites sell!
As I said, at that price give it a go. This may sound obvious but make sure you have taken into account the route the cable will take when measuring the distance - around doors, following the wall etc, not the direct line of sight. Looping over a door can easily add 5m on its own and you probably want a bit of play at the end.
Good luck
27-10-2014 1:19 PM
The Curry's cable in the OP is one you definitely DO NOT WANT as it's not made of twisted pair cable. As a rule all flat cables are not twisted pair.
RJ11 cables using Cat5e will be twisted pair and you can also get screened ones such as the Tandy one linked above http://www.tandyonline.co.uk/electronics/telecoms-dsl.html and is perfect for the job. Many Plusnet users have used their cables of varying lengths.
The Amazon ones Jim linked in reply #1 are fine as well (but not screened).
My only concern about the modem/router placement high up in a kitchen is it could get a bit to hot for it. You'll have to see how it goes. Make sure plenty of (ideally cool) air can flow through that area.
27-10-2014 1:25 PM
27-10-2014 1:31 PM
