Router on its last legs, or line fault ?
- Router on its last legs, or line fault ?
22-02-2013 11:26 PM
My sync rate is around 13000, my ping is allways 5 ms, and my speed usually sits around 11 Mbps. The last 2 days my speed has been crazy. Going from 7 Mbps up to 24 Mbps. Ping has gone from 5 ms up to 26 ms.
Doing a speed test the speed sits at 2 to 3 Mbps for around 7 seconds, shoots up to 70 + Mbps, then drops back to 20+. I have changed gateways, restarted my router, my exchange is green.
Message 1 of 5
(1,085 Views)
4 REPLIES 4
Re: Router on its last legs, or line fault ?
23-02-2013 7:58 AM
Maybe it's speedtest.net? How long has your router held it current sync rate?
Message 2 of 5
(455 Views)
23-02-2013 8:07 AM
Have you put any new anti virus / security software on? I think kaspersky used to mess up such results.
Message 3 of 5
(455 Views)
23-02-2013 12:45 PM
Thanks for the replies,
My connection has been up for weeks ReedRichards, apart from the odd Peer terminate.
Nice one dvorak, I have been using AVG free for years but after my last format, after I put AVG on it refused to download anything, for example skype,it would get to 98% then would say it couldn't download it, same as with the new intel ethernet drivers. So I put Kaspersky on which was free with my motherboard disk. I have put AVG free back on and the speed test is back to normal.
Thanks, again.
Thanks, again.
Message 4 of 5
(455 Views)
25-02-2013 1:44 PM
If you haven't tried it you might quite like Microsoft Security Essentials? It's lightweight, fast and nag free, or at least I've found it to be so. Just a suggestion though.
Message 5 of 5
(455 Views)
