Router Disconnecting in the Night
- Re: Router Disconnecting in the Night
22-05-2011 6:58 AM
Hi guys,
My internet is disconnecting in the night. But, it doesn't always do this. Do you guys have any suggestions on anything I can do? I even manually raised my SNR to 10dB and it still disconnected. This is with a D-Link DSL-2640B. I also have a Netgear DG834GT and it does it on that as well. Another router I have is the 2Wire 2700HGV. Which is very good. But I haven't been using it as it's been a bit funny recently.
But, on my old provider, when I was set to 6dB and and on fast path, my connected would stay up for days and days with no disconnections. So, is there anything I can do? Nothing has changed in my setup.
Message 1 of 7
(1,192 Views)
6 REPLIES 6
23-05-2011 11:40 AM
Hi sjrinfroyle,
Have you tried connecting it to the test socket to see if it still drops out?
Jojo
Jojo
Message 2 of 7
(591 Views)
25-05-2011 4:25 PM
I will try it in the test socket in about 10-15 minutes. Could you run some tests from your end?
Message 3 of 7
(591 Views)
25-05-2011 4:32 PM
Hi sjrinfroyle,
Why change it now when we've got the speed back to 6000?
Jojo
Jojo
Message 4 of 7
(591 Views)
25-05-2011 4:58 PM
Because it was connected for two days at 7400 and then it suddenly disconnected.
Message 5 of 7
(592 Views)
25-05-2011 5:15 PM
I would still say to leave it for now unless we see the speed affected.
Message 6 of 7
(592 Views)
26-05-2011 1:09 PM
Thanks for your help Joanne!
Message 7 of 7
(592 Views)
