Requesting IP reset at Plusnet side as it's gone up on modem reboot
- Re: Requesting IP reset at Plusnet side as it's go...
24-04-2014 6:56 AM
I'd be grateful if a member of the Plusnet Staff can give my IP profile a reset as my IP in BT speed test has risen to 55.86mb as t's gone up a bit after a modem reboot .
Many thamks in advance for you help which is always appreciated
Bjn
Bjn
Message 1 of 3
(807 Views)
2 REPLIES 2
Re: Requesting IP reset at Plusnet side as it's gone up on modem reboot
24-04-2014 1:45 PM
HI Bjn,
I've given your connection profile a nudge. You should see a slight increase soon.
Message 2 of 3
(544 Views)
25-04-2014 7:02 AM
thanks for the nudge Linn every little helps when you have allot of equipment all using the same bandwidth. The nudge was enough to cover the usage for my sons smart TV watching Netflix in HD.
Message 3 of 3
(544 Views)
