Product Change
- Product Change
Product Change
30-11-2009 12:44 AM
I changed products from 30gb usage to 80gb usage as it is well cheaper and more usage, it said it will be active for the next billing date (30th) today, but i checked then and it said up to 30gb usage only!
Please help!
Lee
Re: Product Change
30-11-2009 1:10 AM
As midnight - 8am doesn't count towards your usage anyway it's not going to affect anything.
Re: Product Change
30-11-2009 1:12 AM
adie:quote
Re: Product Change
30-11-2009 10:36 AM
Is this normal?
Re: Product Change
30-11-2009 10:59 AM
Re: Product Change
30-11-2009 12:02 PM
SKELMERSDALE
Estimated line speed:
3.0 - Checked on 2009-11-24 18:16:02
Current line speed:
2000
Its gone down! I wish they would of told me that i would lose a meg!
Re: Product Change
30-11-2009 12:20 PM
This is a known glitch
Re: Product Change
30-11-2009 12:23 PM
Re: Product Change
30-11-2009 12:29 PM
Re: Product Change
30-11-2009 2:48 PM
Atm im on 1800mbs usually near 2900 and loading pages etc are taking longer than usual.
Re: Product Change
30-11-2009 2:52 PM
Re: Product Change
30-11-2009 3:04 PM
I dont mean to hijack your thread dude, sorry
But this is a known glitch?
Chris check mine aswel then please
MIght have somethign to do with my problem.. I recently swapped from Pro to Premium aswel hmmm!!
Re: Product Change
30-11-2009 3:51 PM
Re: Product Change
30-11-2009 5:03 PM
Re: Product Change
30-11-2009 5:18 PM
Quote from: Chris I've checked yours again and it's set to 4000 (which is correct compared to the IP Profile).
Same, thanks. Just wanted to make sure
