Problems with internet connection dropping
- Re: Problems with internet connection dropping
27-07-2009 7:44 AM
Re: Is There Problems With Plusnet Today? Can't Connect
27-07-2009 7:47 AM
27-07-2009 7:49 AM
27-07-2009 7:54 AM
27-07-2009 9:27 AM
If anything it sounds like your router dropped the connection and just needed a little help to remember how to do its job properly.
Feel free to shout up if you have any furhter difficulties.
27-07-2009 9:46 AM
27-07-2009 9:58 AM
I hope not too.
I've just checked the connectivity logs against your account and whilst I can see that there have been a couple of drops today, over the last week the connection has been very stable.
The best bet is to keep an eye on it and we can raise with BT if it does continue.
27-07-2009 10:05 AM
Thanks for checking. I hope its not either as its taken a long time to get back up and running to a normal service.
Is there a reason why sometimes connection drops?
Charlie
27-07-2009 10:21 AM
It could be a number of things to be honest with you. It could be anything from an exchange fault, a line fault, an increased pattern of noise on your telephone line, to internal wiring or hardware problems at your end.
18-08-2009 1:59 PM
Had been quite stable since my last post but for the last few days connection keeps dropping and at times it is taken ages to get the connection up and running again. DSL light on router keeps flashing away and we also seem to have a hiss on our home phone. Not quite sure what to do as had problems with this for about 6 months before Open reach came out and said they could not really find what the fault was but said he thought it had been fixed!!
18-08-2009 2:36 PM
Quote from: Charley Well here we go again with internet connection dropping!!
The BT guy who came out to me yesterday told me (and this is totally unconnected with the problem I am having) that a faulty Sky Box will inject an audible signal on your phone line. It's usually one of the neighbours and they probably won't know anything about it!
18-08-2009 2:39 PM
18-08-2009 2:42 PM
18-08-2009 2:43 PM
If you're hearing a hiss on your telephone line then I'm afraid you'll need to give us a ring and get another HOme Phone fault raised.
I'm sorry it's a bit of a pain.
18-08-2009 3:00 PM
It is such a nuisance makes me think again of just getting rid of braodband.
