Pings and Gaming and Dissconnects
- Pings and Gaming and Dissconnects
Re: Pings and Gaming and Dissconnects
16-09-2011 10:40 PM
Also noticed when I use the phone on my line it sounds crackly and quite quiet, there isn't a volume on the phone itself (just a standard £12 BT phone)
BT speed tester doesn't seem to show any problems line speed wise, seems that's the max I'll get.. ok its a little lower than the downstream.
Quote Download speedachieved during the test was - 2290 Kbps
Additional Information:
Your DSL Connection Rate :3616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
Just trying to work out what to do, do I fork out £100 on a decent netgear or linksys ADSL router since thats what an N one costs. Is there a fault on my line or something or is this interleaving cause me more problems?
Edit: If i get a new router I'm looking at Buffalo G300H
17-09-2011 12:08 AM
Your sync/connection speed is about right for 56dB attenuation. If your present sync speed is maintained for 4-5 days your IP Profile should increase to 3000kbps.
17-09-2011 3:02 PM
17-09-2011 11:10 PM
17-09-2011 11:34 PM
Also this picture shows the high ping/latency I get in Battlefield Bad Company 2 and tonight I got 2-3 disconnects too
BFBC2 Screenshot
18-09-2011 6:47 PM
18-09-2011 8:39 PM
18-09-2011 10:51 PM
Phone plugged straight into wall socket = No background Noise, Quiet line (how I expect it to be)
Phone plugged into filter with no ADSL connected = Same as above
Phone plugged into filter this time with ADSL conncted = background hiss/noise
Now you get 2 filters supplied with the new router I had delivered by plusnet, both filters do the same. I've even tried another filter I've found from my old modem I had in my last place but that made no difference. Also tried a different cable from the filter to the modem/router no difference.
So 3 different filters and 2 different modem cables and still can't get rid of the noise in the background.
Not sure what else is left to do
18-09-2011 11:04 PM
But connecting that and getting the ADSL all up and running with internet working I didn't get any background hiss on the line with my phone, seems its something to do with this Thompson Router I recently got
19-09-2011 8:29 PM
If you want to buy your own wireless N router the spec for the Buffalo model you mentioned previously looks OK to me, though I've no personal experience of the brand.
19-09-2011 10:35 PM
19-09-2011 11:29 PM
19-09-2011 11:34 PM
20-09-2011 10:30 AM
20-09-2011 3:55 PM
Quote from: KingPenguinUK Ok another update, decided to hunt the old modem I use to use. Speedtouch 517 I think it is, its the non-wireless one so not very good for what I need now. (ie wireless etc)
I assume that router was a Speedtouch 516 but seems to me to answer the "try another router" request.
