Pings and Gaming and Dissconnects
- Pings and Gaming and Dissconnects
Re: Pings and Gaming and Dissconnects
20-09-2011 4:18 PM
I've ordered a replacement router for you to see if that sorts it, it should be with you by the end of the week. Hope that solves the problem for you.
20-09-2011 5:33 PM
My concern is that I get this replacement router and that does the same too, then I'm stuck as to solving this, do I spend money on a new modem/router from another source and find that does the same thing? or just go back to the old speedtouch and then buy a separate router for the wireless side of things.
20-09-2011 7:20 PM
If you connect to your current router using a cable you could try turning wireless off - if you hold in the button on the front for a few seconds it toggles wireless off and on.
Rather than worrying about problems that hopefully will not be there let's see how you get on with the replacement router.
22-09-2011 9:16 PM
I did a BT Speedtest
Quote Download speedachieved during the test was - 902 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2528 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
My IP profile is lower than it usually is too, normally that's been around 3700Kbps
Edit: Getting tired of this now, been kicked 3-4 times tonight from servers either because I have a high ping or I lose connection to the server.... its getting beyond a joke now.
23-09-2011 1:46 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13167817957918.png" />
Other than the usual wiring and master socket checks there's not really much we can recommend for the moment I'm afraid.
23-09-2011 2:51 PM
Take it the IP profile should increase after a couple days of normal use and no disconnects?
23-09-2011 3:10 PM
27-09-2011 2:39 PM
Also when I was changing the router over I double checked with my phone and yes the line was perfectly quiet without the modem connected.
Also did some more ping tests and still the first hop to the router/modem is very high 99-100ms when it should be below 10ms.
Not sure what else to do, I do need an N wireless router for my TV/Blueray system so I'm going to buy one this week see how that goes.
27-09-2011 4:39 PM
As you said, you got a fault (just like me, same rubbish, despite me being on fibre).... As the fault has occured for me since having FTTC activated, then its PN i have to go through to arrange for them to get BT to look into my fault....
If they wont fix the fault, or provide a QoS , then theres always another action
27-09-2011 6:34 PM
Quote from: KingPenguinUK Well my new router that Matt kindly sent out arrived yesterday, Set it up following the book provided and its still doing the same thing as the last router
When you swapped routers did you also swap the DSL cable from the router to the filter, and the filter as well?
27-09-2011 11:00 PM
@Jaggies, Yes swapped everything, Power supply, Cat5 cable, Filters and ADSL cable, swapped everything
28-09-2011 1:45 PM
Its fixed one problems, I don't get any more high pings on the first hop (ie PC to router) when tracert to a IP.
But the noise is still on the line but I think this is the Wireless feeding back of some sort. Maybe the filter isn't that great with a wireless router.
Edit: with the new router I take it DSL setting should be on Multimode (Or do I select ADSL2 or 2+ etc?) and VC Setting should be LLC? (or VC)
28-09-2011 2:05 PM
Please see here for router settings: http://www.plus.net/support/broadband/help_and_setup/connections_settings.shtml
28-09-2011 2:20 PM
29-09-2011 3:25 PM
As for the background noise down the line when a wireless router is connected I've still not solved, I have a new ADSL filter from ADSL Nation coming, going to see if that helps (its meant to be the best on the market)
