Ping High and Upload Speed Low
- Ping High and Upload Speed Low
Re: Ping High and Upload Speed Low
20-04-2013 11:13 AM
20-04-2013 12:43 PM
2.2.1 Dynamic Line Management
Dynamic Line Management (DLM) is employed in GEA-FTTC. DLM constantly
manages lines to maintain a target link quality (speed and stability). It does this for as
long as the product exists.
At provision, the line is put on “wide open” VDSL2 line profiles allowing the
upstream and downstream line speeds to run at the upper limit of the product option
selected.
On the first day of operation, DLM will intervene if severe instability is detected.
Otherwise, DLM will wait until the day after provision before deciding if it must
intervene, provided that the line has been trained up for at least 15 minutes during the
preceding day.
If DLM intervenes it will set a profile with a maximum rate and a minimum rate,
where the minimum rate is set at approximately half of the maximum rate. The
purpose of the minimum rate is to ensure that the line does not train at a rate which is
significantly below the level the line should be able to achieve. If this happened, then
the line is likely to remain at a very low rate until a re-train is forced by the user by
powering off the modem.
Note : It is the DLM system thatsetsthe line profile, and this should not be interfered
with by CPs/users setting rates, SNR margins etc. at the modem.
Note : The upstream throughput is also constrained on the DSLAM to the upstream
rate requested in the order, i.e. 2Mbit/s, 10Mbit/s or 20Mbit/s, so even if the VDSL2
upstream line speed is higher, the upstream throughput is constrained to the level
ordered for the product.
Thanks for the info dannystokie
20-04-2013 12:52 PM
20-04-2013 1:32 PM
20-04-2013 2:43 PM
20-04-2013 11:48 PM
21-04-2013 11:01 AM
21-04-2013 11:57 AM
I sync at 80/20 but achieve 70-72 down and 16-17 up on speedtests.
21-04-2013 11:59 AM
22-04-2013 9:27 AM
22-04-2013 10:22 AM
Now upload speed is what I should be getting!
Took that speed test on my HTC One.
22-04-2013 11:36 AM
Here is what i generally get
Wired Desktop; 60-73 down and 15-18up.
Ipad3 (latest version of IOS) 38-40 down 18up (Scale only goes to 50Mbits)
Nexus 4: 10-35 down 18-19 up. (This test finishes very quickly compared to other two platforms and signal meter only goes up to 20Mbits with needle off the scale anyway when its running before giving results higher than meter shows lol)
IP Profile has settled (fingers crossed) at 77.44Mbits and 20Mbits down
For my wireless to be going quicker on upload than a wired connection is dubious to me
22-04-2013 11:44 AM
But even so still hating the download speeds, and the fact my IP profile has been reduced, and ping is still high again.
22-04-2013 11:55 AM
I think what I find frustrating is the lack of connection stats due to having locked down OR modems. I am so used to having these details on my ADSL connection lol and could see when something was up (should that be down in terms of speed) lol..
22-04-2013 2:27 PM
