Ping High and Upload Speed Low
- Ping High and Upload Speed Low
18-04-2013 11:33 AM
Had fibre unlimited installed yesterday, can't complain about the download speeds though.
Although, ping seems to high, I was getting less than that on normal broadband, and upload speed is low, should be getting a lot closer to 20mbps as told by the openreach engineer and BTW Diagnostics.
Liam
Re: Ping High and Upload Speed Low
18-04-2013 11:42 AM
18-04-2013 11:47 AM
18-04-2013 6:12 PM
18-04-2013 6:55 PM
19-04-2013 12:53 AM
19-04-2013 2:18 AM
To get a more accurate result of your speed go to http://www.speedtest.btwholesale.com/
19-04-2013 11:16 AM
19-04-2013 10:46 PM
Download Speed
48.54 Mbps
0 Mbps 76.91 Mbps
Max Achievable Speed
Download speedachieved during the test was - 48.54 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-76.91 Mbps .
Additional Information:
IP Profile for your line is - 76.91 Mbps
Upload Speed
15.07 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 15.07Mbps
Ping is better:
Highest I got:
20-04-2013 7:40 AM
20-04-2013 9:20 AM
20-04-2013 9:46 AM
20-04-2013 10:50 AM
1. Best Effort Test: -provides background information.
Download Speed
25.57 Mbps
0 Mbps 76.91 Mbps
Download speedachieved during the test was - 25.57 Mbps
Upload Speed
14.54 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 14.54Mbps
20-04-2013 10:58 AM
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
If there is still a fault I'm sure Plusnet will look into this after the 10 day training period.
20-04-2013 11:07 AM
