PN - major service incident
- Re: PN - major service incident
30-11-2014 12:53 PM
30-11-2014 12:58 PM
30-11-2014 12:59 PM
30-11-2014 1:03 PM
They also need to explain why these events are happening... but complaining about those things today does not move the situation forwards.
30-11-2014 1:03 PM
30-11-2014 1:04 PM
30-11-2014 1:11 PM
Quote from: mitch0 There's my day of work down the drain. Thanks Plusnet.
Any sort of timescale yet for when they are going to fix it?
Why on earth are you subscribing to a "cheap as chips" domestic broadband supplier if you are using it for essential work?
You should be using a business grade supplier with defined SLA's and umpteen backup plans if BB is essential to you for whatever reason - and yes you will pay a lot for it.
30-11-2014 1:15 PM
30-11-2014 1:16 PM
30-11-2014 1:22 PM
If you find one with true uptime guarantees on their edge kit let me know.
There are 10's of thousands of business customers using Plusnet due to the excellent business packages, superb, dedicated business support and enhanced care levels available to business customers. What's letting that down, is sub standard edge kit.
A relatively recent infra change needs resolving, quickly. If that's done, then Plusnet are back to being a good choice for Businesses, if not, then the answer is obvious.
30-11-2014 1:24 PM
anyhow its back up for now and hopefully will stay that way
30-11-2014 1:26 PM
30-11-2014 1:27 PM
30-11-2014 1:37 PM
30-11-2014 1:42 PM
