PLUS net network routing broken!!
- Re: PLUS net network routing broken!!
15-05-2009 11:31 AM
I have an open ticket regards surfing speeds - which appeared as an intermittent fault until today ...
something MUST be wrong with routing on the plusnet network .... today the symptoms are:-
plusnet portal - fine but a bit sluggish
google images search - works ok, but a bit sluggish
http://technet.microsoft.com ; - 404 error page not wound
http://www.microsoft.com ; - just hangs and will no doubt timeout
cnet news pages regards the recent google outage - 404 error
the fact i can goole fine but places like microsoft, cnet are unreachable has to be a plusnet network issue ... come on guys - i have been a happy customer for many years but this is now almost a week of dismal service ... and i will have to consider going elsewhere - my next door neighbours internet, using a different ISP is fine, no noise on my phone line etc
I have tried from different pc's etc and its all the same
my router info:- Netgear DG834GT ...
Firmware Version V1.02.19
ADSL Port
MAC Address 00:0F:B5:C0:BD:CF
IP Address 80.229.250.155
Network Type PPPoA
IP Subnet Mask 255.255.255.255
Gateway IP Address 195.166.128.80
Domain Name Server 212.159.6.9
212.159.6.10
LAN Port
MAC Address 00:0F:B5:C0:BD:CE
IP Address 192.168.2.1
DHCP On
IP Subnet Mask 255.255.255.0
Modem
ADSL Firmware Version A2pB022c.d20e
Modem Status Connected
DownStream Connection Speed 1312 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
C:\Program Files\Support Tools>tracert www.microsoft.com
Tracing route to lb1.www.ms.akadns.net [207.46.193.254]
over a maximum of 30 hops:
1 856 ms 519 ms 172 ms 192.168.2.1
2 358 ms 41 ms 1544 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 286 ms 108 ms 41 ms vl303.thn-gw2.plus.net [84.92.3.178]
4 252 ms 190 ms 38 ms ldn-b4-link.telia.net [213.248.84.197]
5 37 ms 99 ms 98 ms ldn-bb2-link.telia.net [80.91.251.14]
6 1247 ms 502 ms 118 ms ash-bb1-link.telia.net [80.91.251.207]
7 118 ms 741 ms 196 ms microsoft-ic-119510-ash-bb1.c.telia.net [213.248
.89.18]
8 247 ms 248 ms 128 ms 209.240.199.99
9 229 ms 1493 ms 760 ms ge-6-1-0-0.bl2-64c-1b.ntwk.msn.net [207.46.43.27
10 250 ms 269 ms 970 ms ge-3-1-0-0.co2-64c-1a.ntwk.msn.net [207.46.35.14
9]
11 631 ms 178 ms 179 ms ge-0-1-0-0.wst-64cb-1a.ntwk.msn.net [207.46.43.1
95]
12 409 ms 791 ms 761 ms ge-0-2-0-0.tuk-64cb-1b.ntwk.msn.net [207.46.47.7
0]
13 631 ms 180 ms 191 ms 207.46.47.68
14 244 ms 185 ms 178 ms ten1-4.tuk-76c-1a.ntwk.msn.net [207.46.46.11]
15 176 ms 181 ms 281 ms po16.tuk-65ns-mcs-1b.ntwk.msn.net [207.46.35.142
16 * * * Request timed out.
17 * * * Request timed out.
18 ^C
the time from pc to my router is a little high - but my home network is good enough to stream movies across it .... so that can't be the cause ...
rebooted the router last night ...
System Up Time 13:57:28
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 320221 233196 0 5041 2078 13:56:54
LAN 10M/100M 73530 125076 0 690 331 13:57:23
WLAN 11M/54M/108M 262247 372865 0 1698 5090 13:57:17
ADSL Link Downstream Upstream
Connection Speed 1312 kbps 448 kbps
Line Attenuation 63.5 db 31.5 db
Noise Margin 6.5 db 10.0 db
thoughts, other than 2 tin cans a a very long piece of string ...
Dave
15-05-2009 11:33 AM
Quote 1 856 ms 519 ms 172 ms 192.168.2.1
That's almost a second from your PC to your Router. I'd suggest that there's either a software issue on your PC or (possibly more likely) an issue with your network card, network cable or router itself.
15-05-2009 11:40 AM
To do this have a look here for Xp or here for Vista.
Aslo set the MTU in your router to 1500 (if it's settable). The router MTU should always be the same as, or more than, the MTU on the PC(s).
If it's an Xp machine you're using I'd set RWIN to 166800, as suggested on the linked page. You can't set RWIN on Vista (nor do you need to!).
Edit: typos
15-05-2009 11:52 AM
15-05-2009 11:57 AM
Quote but would would i be able to get to bbc, google, cnn but not cnet, microsoft, yahoo ... ?
I assume you're talking about tweaking the MTU?
If you adjust the MTU downwards (it's probaly at the default of 1500 if you've never adjusted it) you'll not break any sites that already work OK (you may make them load a bit faster though, as it often improves your throughput) but will likely fix those that are broken just now!
(Also, don't keep lowering the MTU ever downwards - 1430 is about as low as you want (or need) to go.)
15-05-2009 12:13 PM
Quote from: DaveS00 time to plug a pc directly into the router with a nice short patch lead!
Does that mean you are usually wireless?
15-05-2009 12:15 PM
15-05-2009 12:34 PM
I have 2 XP desktop which used netgear hd - ethernet of mains adapters - so one of these could be problematical ... hence the short patch lead and need to do the trace from vista - but 95% of the issues have been vista/wireless - the trace info in this post is one of the XP boxes - but not the media server. This XP box is rarely used .. but symptoms are very similar to Vista laptop
15-05-2009 12:49 PM
Quote from: DaveS00 1 856 ms 519 ms 172 ms 192.168.2.1
Just like Everest is a little high!
My daughters PC is at the diagonally opposite corner of our house from the wireless access point (bedroom upstairs to office downstairs), in addition the office is in an extension so there's what was an external cavity wall in between. In short the signal is carp and the connection speed constantly varies between nothing and about 11mbps maximum - typical around 2-4mbps.
Here's her ping to the router:
>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time=13ms TTL=255
Reply from 192.168.0.1: bytes=32 time=4ms TTL=255
Reply from 192.168.0.1: bytes=32 time=6ms TTL=255
Ping statistics for 192.168.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 4ms, Maximum = 13ms, Average = 7ms
Your ping isn't bad, it's excruciatingly, appallingly awful!
15-05-2009 7:11 PM
a different XP pc .... with ok ping times to router ...
C:\Documents and Settings\Dave>ping -t 192.168.2.1
Pinging 192.168.2.1 with 32 bytes of data:
Reply from 192.168.2.1: bytes=32 time=117ms TTL=64
Reply from 192.168.2.1: bytes=32 time=3ms TTL=64
Reply from 192.168.2.1: bytes=32 time=5ms TTL=64
Reply from 192.168.2.1: bytes=32 time=6ms TTL=64
Reply from 192.168.2.1: bytes=32 time=96ms TTL=64
Reply from 192.168.2.1: bytes=32 time=7ms TTL=64
Reply from 192.168.2.1: bytes=32 time=86ms TTL=64
Reply from 192.168.2.1: bytes=32 time=87ms TTL=64
Reply from 192.168.2.1: bytes=32 time=88ms TTL=64
Ping statistics for 192.168.2.1:
Packets: Sent = 15, Received = 15, Lost = 0 (0% loss),
Minimum = 3ms, Maximum = 117ms, Average = 35ms
Control-C
^C
trace to microsoft site - remebering this all worked fine a couple of weeks back and this pc has absolutely no change s- not even AV updates (don't ask!) ....
C:\Documents and Settings\Dave>tracert www.microsoft.com
Tracing route to lb1.www.ms.akadns.net [207.46.19.254]
1 6 ms 4 ms 5 ms 192.168.2.1
2 35 ms 63 ms 45 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 37 ms 32 ms 36 ms vl303.thn-gw2.plus.net [84.92.3.178]
4 42 ms 140 ms 45 ms ldn-b4-link.telia.net [213.248.84.197]
5 37 ms 33 ms 41 ms ldn-bb1-link.telia.net [80.91.249.131]
6 121 ms 109 ms 112 ms ash-bb1-link.telia.net [213.248.65.98]
8 * * * Request timed out.
9 ^C
1 7 ms 4 ms 4 ms 192.168.2.1
2 36 ms 33 ms 36 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 37 ms 36 ms 36 ms vl303.thn-gw2.plus.net [84.92.3.178]
4 40 ms 36 ms 41 ms ldn-b4-link.telia.net [213.248.84.197]
5 31 ms 36 ms 36 ms ldn-bb2-link.telia.net [80.91.254.21]
6 107 ms 108 ms 109 ms ash-bb1-link.telia.net [213.248.65.98]
9 ^C
bbc ... which works fine ...
C:\Documents and Settings\Dave>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.253.67]
1 8 ms 73 ms 4 ms 192.168.2.1
2 134 ms 31 ms 46 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 36 ms 32 ms 134 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 221 ms 198 ms 204 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 49 ms 69 ms 162 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 241 ms 99 ms 36 ms 212.58.238.133
7 95 ms 106 ms 41 ms te12-1.hsw0.cwwtf.bbc.co.uk [212.58.239.222]
9 * * * Request timed out.
10 ^C
yahoo ... which fails ... in the web browser
C:\Documents and Settings\Dave>tracert www.yahoo.com
Tracing route to www-real.wa1.b.yahoo.com [87.248.113.14]
1 11 ms 4 ms 7 ms 192.168.2.1
2 40 ms 197 ms 215 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 216 ms 191 ms 41 ms vl303.thn-gw2.plus.net [84.92.3.178]
4 43 ms 37 ms 38 ms vl23.pte-gw2.plus.net [212.159.4.28]
5 41 ms 41 ms 31 ms ge-1-1-0.pat1.the.yahoo.com [195.66.224.129]
6 130 ms 100 ms 41 ms so-0-1-0.msr1.ird.yahoo.com [66.196.65.33]
7 46 ms 44 ms 47 ms gi-1-5.bas-b1.ird.yahoo.com [87.248.101.23]
8 141 ms 45 ms 118 ms f1.us.www.vip.ird.yahoo.com [87.248.113.14]
Trace complete.
ideas please ...
15-05-2009 8:38 PM
It's worth a try. As I said before it often cures this sort of problem as it will reduce the packet size to avoid fragmentation. The fault isn't with your set up but with "broken" routers on the way to the sites in question which aren't allowing MTU path discovery to work properly. Lowering the MTU will allow the packets through these routers.
16-05-2009 4:55 PM
17-05-2009 8:29 PM
I can also now run www.mybroabandspeed - which just failed to load for the last 2 weeks - so things are better
The issues with the network to my router are resolved, so decent ping times.
I know just have chronic ftp speeds ...
I am downloading from http://masseffect.bioware.com/galacticcodex/bringdownthesky_pc.html and get appalling speeds - 6 kb/s, (as measured in firefox), with it "hiccupping" and showing 0 kb/s at times.
Its not the source webserver at fault, as a friend is getting a download speed of 200 kb/s from the same server, pulling down the same file, they live in a town about 15 miles away (so a different phone exchange, and different isp)
any ideas?
17-05-2009 8:45 PM
17-05-2009 9:20 PM
C:\Users\Dave>ping -t 192.168.2.1
Reply from 192.168.2.1: bytes=32 time=1ms TTL=64
Packets: Sent = 8, Received = 8, Lost = 0 (0% loss),
Minimum = 1ms, Maximum = 1ms, Average = 1ms
Control-C
^C
