New vdsl Modem
- New vdsl Modem
Re: New vdsl Modem
09-09-2014 6:01 PM
Re: New vdsl Modem
09-09-2014 6:04 PM
MisterW, looking further down the thread it looks like it's possible to cross flash the W8980 with W9980 firmware. Might bottle it & just pay the extra £12 for the W9980.
Cheers lads.
Re: New vdsl Modem
09-09-2014 7:37 PM
Quote That won't be in stock for a few more weeks.
They are currently in the process of being shipped to the Uk. Final UK firmware just being tidied up.
Quote baby up, especially vdsl side of things. Who do I ask
It should be very easy for Plusnet users. There will be a quick set up which will take care of most of the configuration
Ive not seen the final release firmware yet with full quickstart menu, but they have been supplied with the details needed to auto-setup for Plusnet/BT etc for vdsl.
It should be simply a case of selecting ADSL or VDSL, then selecting your ISP from a dropdown menu, then entering your username and password.
Even without the quick-start its still quite intuitive. Although the interface isnt the same... all the info you need to input is here
http://www.kitz.co.uk/routers/zyxel_VMG8324-B10A_vdsl_setup.htm
Quote What do you guys think to this kit,
As this isnt yet available for purchase, unfortunately there wont be any public feedback yet. But hopefully something should be released quite soon
Re: New vdsl Modem
09-09-2014 7:51 PM
Although someone has been able to flash a TD-W8980 with TD-W9980 firmware. That isnt the new UK firmware what he's used and theres more up to date versions. AFAIK its not a straight forward flash and you'd need to use a TTL serial adapter - best asking zhadoom if you want more info on that.
Re: New vdsl Modem
10-09-2014 8:07 AM
Sorry for the dumb question but where will I be able to access my vdsl plusnet username & password to enter into the new Modem/Router ?
Cheers.
Re: New vdsl Modem
10-09-2014 8:24 AM
It's the same username as the one you use to login to the member centre but with @plusdsl.net on the end. See here http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Quote Sorry for the dumb question but where will I be able to access my vdsl plusnet username & password to enter into the new Modem/Router ?
Re: New vdsl Modem
10-09-2014 1:45 PM
(600MBPS N) NOW IN STOCK!
For more information or to order see:
http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=17047
Regards,
Broadbandbuyer.co.uk
Re: New vdsl Modem
10-09-2014 2:00 PM
Re: New vdsl Modem
10-09-2014 2:25 PM
Re: New vdsl Modem
10-09-2014 8:47 PM
Do me a favor & let me know how you get on with this new router as I won't be ordering mine until w/c 22/09 as my install data is 25/09.
I know I already asked this question but am I best leaving the BT Modem in place for a few days once the engineer has been for the install. Does it have to sync & settle in before I start swapping kit.
Cheers.
Re: New vdsl Modem
10-09-2014 8:52 PM
Sure will do. As it will arrived tomorrow as I will set it up and see how it go.
Re: New vdsl Modem
10-09-2014 11:12 PM
TP Link TD-W9980 - Review
@goldenfibre - I'd be interested to know which firmware yours comes with.
Re: New vdsl Modem
10-09-2014 11:44 PM
Re: New vdsl Modem
11-09-2014 12:04 AM
Re: New vdsl Modem
11-09-2014 11:06 AM
What are the correct setting for FTTC Plusnet below:
Isp list: ?
PVC: ?
Connection Type: ?
Encapsulation Mode: ?
L2 Interface Type: vdsl / vdsl2 ?
Enable Vlan: ID tick or untick ?
VID: (1-4094) ?
PPPoE or PPPoA ?
