New vdsl Modem
- New vdsl Modem
Re: New vdsl Modem
11-09-2014 11:15 AM
Re: New vdsl Modem
11-09-2014 11:38 AM
PVC: 0/38
Connection Type: PPPoE
Encapsulation Mode: VCMUX
L2 Interface Type: VDSL2
Enable Vlan: Enabled
VID: (1-4094): 101
PPPoE or PPPoA: PPPoE
with plusnet username and password and still won't work? Cannot get my head round it.
Re: New vdsl Modem
11-09-2014 11:48 AM
Re: New vdsl Modem
11-09-2014 11:52 AM
Re: New vdsl Modem
11-09-2014 12:17 PM
Have you checked the 'operation mode' ? , page 18 , it needs to be xDSL modem router mode
Re: New vdsl Modem
11-09-2014 12:24 PM
Wireless Router Mode: In this mode, the device enables multi-users to share Internet via Ethernet WAN (EWAN) using its interchangeable LAN4/WAN port and share it wirelessly at 300Mbps wireless 802.11n speeds.
I set to xDSL Modem Router Mode and still won't syncing! I am getting frustrated and annoyed now. Probably the worse set up in my own experience.
Re: New vdsl Modem
11-09-2014 12:34 PM
and are you using the RJ11 lead that came with the router ? I've seen different routers use different pairs of the cable , so you often need to use the exact cable that came with the router.
Re: New vdsl Modem
11-09-2014 12:44 PM
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/B/L/M
Upstream Downstream
Current Rate (Kbps) 19999 79995
Max Rate (Kbps) 33519 97876
SNR Margin (dB) 15.2 12.3
Line Attenuation (dB) 1.9 6.0
Errors (Pkts) 0 0
Re: New vdsl Modem
11-09-2014 1:01 PM
It's all a bad idea imho, stick with the HG612 and add a normal ethernet router that does PPPoE. At this rate, when vectoring comes, those people with their own random VDSL modems will screw over the rest of us
Re: New vdsl Modem
11-09-2014 1:04 PM
I assume the TP-Link has similar options to the Technicolour to restrict access for certain devices? Finding that very useful to block kids ipods/kindles at night when they should be sleeping!
Re: New vdsl Modem
11-09-2014 1:08 PM
You can download the full user guide from here http://uk.tp-link.com/products/details/?categoryid=3788&model=TD-W9980#down
Quote I assume the TP-Link has similar options to the Technicolour to restrict access for certain devices?
Re: New vdsl Modem
11-09-2014 1:17 PM
TP-Link:
Upstream Downstream
Errors (Pkts) 0 0
BT Openreach HG612:
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 36672 Kbps, Downstream rate = 104316 Kbps
Path: 0, Upstream rate = 19999 Kbps, Downstream rate = 79987 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 13.2 23.0
Attn(dB): 0.0 0.0
Pwr(dBm): 12.5 -0.3
Re: New vdsl Modem
11-09-2014 2:36 PM
Re: New vdsl Modem
11-09-2014 2:55 PM
Re: New vdsl Modem
12-09-2014 8:48 AM
Got a bit spooked by 'rtho782' comments about the vectoring issue, something to worry about ?
Cheers for all your advice so far
