NOT Connected To GREEN CABINET At End of My Drive.
- NOT Connected To GREEN CABINET At End of My Drive.
Re: NOT Connected To GREEN CABINET At End of My Drive.
12-01-2013 11:06 PM
12-01-2013 11:31 PM
Sorry - nope.
Quote from: ReedRichards Perhaps if a brand new cabinet is installed it combines both wire and fibre?
12-01-2013 11:39 PM
Quote from: Mark Only way to get on to that cab would be to order a new phone line. Once installed you could move your existing FTTC service to that line and probably renumber the new line to your existing number. It'll cost and there's potential for things to go wrong.
A second line is normally supplied by using a spare pair in the first cable. So that wouldn't work. (OK, the cable from the house only goes to the first distribution point, but the feed to that is probably from the just one cabinet, and so on .... Even if a distribution point has two feeds, cross-connecting sounds hairy).
Even if a completely fresh cable from the PCP paired with the nearby FTTC cabinet could be obtained, migrating FTTC between two lines at the same address, served by two different cabinets, seems unlikely to be catered for in any of the ordering systems involved.
I'm not sure how feasible the renumbering (both lines) would be either.
Nightmare.
13-01-2013 8:43 AM
Quote from: Estragon Sorry - nope.
Then it's not an FTTC cabinet despite what SarahCook62 was told. What I was told (in a presentation given by BT to my local council) is that:
- Fibre cabinets make a little noise because there are cooling fans inside.
- They are always paired with a 'regular' wire cabinet which must be close by.
SarahCook62, I suggest that you compare what is outside your house with the cabinets a mile away to which you have been connected.
13-01-2013 10:37 AM
13-01-2013 10:58 AM
Quote from: ReedRichards They are always paired with a 'regular' wire cabinet which must be close by.
Define close I've seen some fibre cabinets that are several 10's of metres apart and there is one that I still have not found the PCP it's paired with. All to do with where the fibre cabinet can pick up a mains supply. The fibre cabinet that I can not see the paired PCP is using a supply from Belisha Beacons.
13-01-2013 11:13 AM
Quote from: itsme Define close
Within 30 metres, perhaps? The broadband signal has to travel from the fibre cabinet to the 'PCP' and thence to your house down copper wires. So if the two cabinets are far apart it starts to defeat the object. And I presume the cost of the cable linking the two cabinets increases in proportion to their separation.
13-01-2013 11:20 AM
The PCP is over a junction then along a fair bit (towards the exchange) from the FTTC cabinet. I can't understand why they did this because the VDSL signal has to go back to the PCP then the phone line travels back again past the FTTC cabinet. Almost all the houses served by the cabinet are nearer the FTTC cabinet than the PCP so nearly everyone has nearly 100m added to the effective length of the VDSL line
13-01-2013 3:30 PM
road......No way can I get on this nearer one as no line across road....They will not dig up a main road......Roger
13-01-2013 4:19 PM
Re cabinet pictures, here's a better link.
13-01-2013 9:36 PM
Quote from: sarahcook62 Well, the cabinet at the end of my drive is a new one, Well i say new but it has been their for a while. There is not another cabinet around it. The one we are apparently connected to is a good mile down the road and on a different street. I understand that the new one by our house was put in after the house etc, so we wouldent be connected to it, but im just wondering how i would go about seeing if we could be transferred or something along those lines.
Try this link to see what cabinet number shows for your address.
http://www.dslchecker.bt.com/pls/adsl/ADSLChecker.Ad...
Boz
13-01-2013 10:04 PM
13-01-2013 10:24 PM
14-01-2013 12:06 AM
14-01-2013 8:21 AM
Quote from: jelv That link doesn't work for me.
Apologies. Try this one.
http://www.dslchecker.bt.com/pls/adsl/ADSLChecker.AddressOutput
Boz
