My ADSL2+ is very slow
- Re: My ADSL2+ is very slow
12-02-2010 10:23 AM
12-02-2010 10:52 AM
You'll need to post some stats from your router to help us.
More information here http://www.kitz.co.uk/adsl/frogstats.php
Cheers
12-02-2010 11:17 AM
I have a BT Voyager 2091 router.
Line Mode ADSL2+ Line State Show Time
Line Power State L0 Line Up Time 00:01:44:08
Line Coding Trellis On Line Up Count 5
Statistics Downstream Upstream
Line Rate 9725 Kbps 444 Kbps
Noise Margin 5.9 dB 27.9 dB
Line Attenuation 29.0 dB 12.3 dB
Output Power 0.0 dBm 12.4 dBm
MSGC (number in overhead channel data) 64 10
B (number of bytes in Mux Frame) 46 63
M (number of Mux Frames in FEC Frame) 1 1
T (Mux Frames over sync bytes) 6 1
R (number of check bytes in FEC Frame) 12 0
S (ratio of FEC over PMD Frame length) 0.1541 4.5310
L (number of bits in PMD Frame) 3063 113
D (interleaver depth) 192 1
Delay 7 msec 1 msec
Super Frames 386192 386190
Super Frame Errors 67 0
RS Words 162200958 0
RS Correctable Errors 82409 0
RS Uncorrectable Errors 1741 0
HEC Errors 57 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
12-02-2010 11:31 AM
DHCP Table
Refresh
Host name MAC address IP address Lease Time
Colin-PC 00:1C:BF:90:7C:16 192.168.1.2 00:20:58:08
minint-mgjujoi 00:1D:09:BB:2E:F4 192.168.1.3 00:08:27:26
Thanks.
12-02-2010 11:34 AM
Interesting that Output Power 0.0 dBm - I would have though it would say something (what I dunno)
Have you :-
a) run a BT Speed test ?
b) tried using the router in the TEST socket (need to give the stats as before)
12-02-2010 11:36 AM
Quote from: Colin1234
It means that another device (IP address 192.168.1.3) is attached to your router either via Wired or Wireless connection. Laptop ? Desktop ? Printer ? Smartphone ?
12-02-2010 11:49 AM
12-02-2010 12:31 PM
12-02-2010 12:32 PM
12-02-2010 12:41 PM
Quote from: stallan OK... So with my (limited) experience a 29DB downstream attenuation should give a higher sync than what you have at the moment. I have a 27db attenuation and sync around 14000 (which is still a shade on the low side according to Kitz stats http://www.kitz.co.uk/adsl/max_speed_calc.php )
Have you :-
Yes I have. I have no test socket behind plate for some reason. I have tested my router on another broadband connection and it worked ok. However, this was not ADSL2+. Plusnet are going to send me a test router one day if they ever get round to it. Be quicker to get my own. Mystery continues.
12-02-2010 12:50 PM
Download speedachieved during the test was - 263 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :9726 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 20.15:42.97:36.88 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
12-02-2010 1:00 PM
12-02-2010 1:13 PM
12-02-2010 1:14 PM
Quote from: Oldjim Can you disable the wireless completely and try connected by cable to the router
Yes. I have just done that. Wifi disabled. On cable connection now. Makes no difference to the speed.
12-02-2010 1:24 PM
Quote from: stallan and also state what your PlusNet Profile says https://portal.plus.net/my.html?action=data_transfer_speed
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
7150
I am getting a better response from you guys than I receive when I create a support ticket with Plusnet. It takes days, if they respond at all. Thanks.
