Mods please delete
- Re: (Legitimate!) DLM reset request
Mods please delete
22-02-2014 8:05 PM
Apologies, no longer an issue, mods please delete!
Message 1 of 3
(680 Views)
2 REPLIES 2
23-02-2014 1:00 AM
DLM has banded /capped your sync by setting this profile, I believe switching between the 40mbps and 80mbps product variant causes a rest of DLM to it's wide open profile, which would be another option available to plusnet, if openreach for some reason wouldn't co -operate with a request to reset DLM I take it that you also have your line rental with plusnet ? if they reported your bb fault as a voice fault to openreach
Message 2 of 3
(422 Views)
23-02-2014 1:01 AM
Quote from: deathtrap DLM has banded /capped your sync by setting this profile, I believe switching between the 40mbps and 80mbps product variant causes a rest of DLM to it's wide open profile, which would be another option available to plusnet, if openreach for some reason wouldn't co -operate with a request to reset DLM I take it that you also have your line rental with plusnet ? if they reported your bb fault as a voice fault to openreach
Yup, all with Plusnet.
Already on 80/20 so would have to go back down to 40 for that to be an option.
Message 3 of 3
(422 Views)
