Modem dropping out
- Modem dropping out
Modem dropping out
20-03-2008 11:46 PM
I'm on Broadband Plus, which is subject to the 30 minute idle timeout rule, but I have been through the process of opting out. At least I think I have - the instructions are far from clear (after you press the 'Activate' button, you are requested to press the 'Deactivate' button if you still want to proceed with the opt-out - what does it all mean?). The modem/router is a Belkin 54g wireless jobbie wired to the main house computer I have recently changed computer to one with Vista installed, which has corrupted the modem's home page a little, so I might have trouble changing the settings to stop the drop-outs, even if I knew what to change.
I'm also using a Squeezebox over a wireless comnnection, but I can't see that making any difference.
What's the most likely cause - Plusnet's idle timeout policy or some Vista compatibility issue? Your help would be most appreciated.
Many thanks,
Dave
Re: Modem dropping out
25-03-2008 11:57 AM
You've definitely got idle timeouts turned off.
I would recommend trying to use a different fuilter and/or modem/router if possible. Also make sure that your router is plugged into your master socket via a filter.
These actions can help to reduce interference which could be the cuase of your disconnections.
25-03-2008 12:07 PM
25-03-2008 12:10 PM
25-03-2008 12:13 PM
25-03-2008 12:13 PM
The drop-outs are far more likely to be caused by interference on your line or a faulty router.
The increase in speed may be due, in part, to Vista's better handling of the TCP/IP connection (assuming that you're talking throughput and not sync speed with the exchange). You don't need to tweak Vista in the same way as you did Xp to get MTU and RWIN set up optimally. In fact, you can't change RWIN in Vista (and it's a bit of a pain to change the MTU).
25-03-2008 12:21 PM
'Dave ..................... we seem to have a problem .................... I do not think I can allow that'
25-03-2008 12:41 PM
If you're saying that it's happening in the evenings, this isn't uncommon. Because more people will be using their phonelines at that time of day/night, there's more noise present on your telephone line, causing a poorer quality of signal, causing the connection to drop.
The suggestions I made earlier can help this though.
25-03-2008 1:48 PM
Does it coincide with central heating coming on in the morning, for example? (Old timers and central heating controls can cause large electrical spikes which can knock out your broadband connection) Is there anything new in your property that could be causing interference?
26-03-2008 10:31 AM
26-03-2008 11:54 AM
Quote from: briston Now this si where I show how little I know. I do have a static IP but the main problem for me is that I have to re-boot my modem/router.
You are getting mixed up with the IP assigned by Plusnet which is the WAN (internet) side of your router and the IP addresses on the LAN (your home network side).
On your router there will be settings for the LAN IP and DHCP configuration. This will give the range of addresses it can allocate. If your router is 192.168.0.1 this will probably be 192.168.0.2 to 192.168.0.254. Change the end figure to 192.168.0.99
On each PC you can now go in to the Network Connections, properties of Local Area Connection, Internet Protocol(TCP/IP) properties and change from Obtain an IP address automatically to Use the following IP address. Assign each PC a different number starting with 192.168.0.100. You will need to enter a subnet mask of 255.255.255.0 and put your routers IP address as the Default gateway. You will also need to specify the DNS servers to use; you can use the router as a DNS server if you wish, or use the Plusnet DNS servers (if entering more than two you need to go in to advanced) which are 212.159.13.49, 212.159.13.50, 212.159.6.9, 212.159.6.10.*
Now your IP address of your PC's will stay the same when you reboot PC or router.
(In all the above addresses you may need to replace 192.168.0 with the first three parts of your router's address)
*Somebody is bound to chip in saying you should use the OpenDNS or other servers - but let's keep it simple to start with!
29-03-2008 5:03 PM
