Low IP Profile and slow connection problem again!
- Re: Low IP Profile and slow connection problem aga...
13-07-2011 11:32 AM
THOMSON TG585 v7
Link Information
Uptime: 0 days, 0:31:40
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 7.5 / 15.0
SN Margin (Up/Down) [dB]: 24.0 / 14.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Results from http://www.speedtester.bt.com/
Download speedachieved during the test was - 1356 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1500 Kbps
Plusnet Current line speed:
6 Mb
Can someone please tell me how to go about getting my IP Profile raised to be in line with my Plusnet line speed. I have tried restarting my router, checking all the micro filters on my line, detaching my sky boxes and telephone connections and nothing has helped to raise the profile. Any advice you can give me would be really useful.
Thanks.
Re: Low IP Profile and slow connection problem again!
13-07-2011 11:51 AM
I'll take a look into this and get back to you.
Jojo
13-07-2011 2:16 PM
I had a similar problem back in May (see my previous posts) but changing the micro filter on my sky+ box sped up my connection almost instantly and reduced the number of errors. Since then the connection has been ok up until about a week ago when I started getting a lot of disconnections (see your records) and a significant reduction in the speed of connection. Over the weekend I did a speed test and saw my IP Profile had been set at 1500 instead of the usual 6500 plus. I changed the filter on my sky+ box again on Monday and the connection was stable (but still slow) for just over 24 hours before I got disconnected again yesterday evening at around 7:30pm. Can you help me find out why I am getting disconnected so frequently at times and why my IP Profile has been set so low?
13-07-2011 3:48 PM
I've been looking into this and the reason your profile is 1500 but higher on our side is that two different parts of the BT systems are reporting 2 different speeds. This is called a consistency fail. I've been in touch with our suppliers and they have applied the change, but said it can take 2 hours to apply.
Jojo
13-07-2011 4:07 PM
13-07-2011 5:18 PM
Link Information
Uptime: 0 days, 0:03:42
SN Margin (Up/Down) [dB]: 24.0 / 14.0
Loss of Framing (Local/Remote): 6 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 5 / 0
Are the results from my router reasonably healthy or are there any figures which stand out as being a problem?
13-07-2011 5:27 PM
14-07-2011 9:13 AM
I've checked this morning and it's still the same. I'm working on how to get this resolved for so leave it with me for a bit and I'll let you know what I manage to do.
Jojo
14-07-2011 9:50 AM
Download speedachieved during the test was - 1382 Kbps
Shortly afterwards I had another loss of signal, the first for about 16 hours. Results from my router were:
Link Information
Uptime: 0 days, 0:21:28
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
SN Margin (Up/Down) [dB]: 24.0 / 12.5
Loss of Framing (Local/Remote): 18 / 0
Loss of Signal (Local/Remote): 2 / 0
Error Seconds (Local/Remote): 6 / 0
My Plusnet current line speed is showing as 6.5 Mb at the moment, so is the problem being caused by BT or Plusnet? If you could keep me updated with the progress in dealing with my complaint I would appreciate it.
14-07-2011 9:53 AM
What you need to do is find any sources of interference that happen in the night. Ask one of the staff members for a connection graph and then you can see when it's disconnecting.
Just my two cents.
14-07-2011 10:03 AM
Needless to say 72 hours later I still have a consistency fail!
14-07-2011 11:01 AM
Quote from: cornwallsurfer not sure where the 2 hours on this thread comes from?
When I was onto our suppliers, they processed a change which they said could take 2 hours. That change didn't make any difference, so I'm still working on it.
Jojo
14-07-2011 11:05 AM
Quote from: sjrinfroyle What you need to do is find any sources of interference that happen in the night. Ask one of the staff members for a connection graph and then you can see when it's disconnecting.
No, it's nothing to do with that. As I explained earlier, one of the systems is showing the correct profile and another isn't. We are just aiming to get that corrected.
Quote from: Joanne I've been looking into this and the reason your profile is 1500 but higher on our side is that two different parts of the BT systems are reporting 2 different speeds. This is called a consistency fail. I've been in touch with our suppliers and they have applied the change, but said it can take 2 hours to apply.
14-07-2011 5:05 PM
[Edit] - Has there been any news on getting this sorted out?
14-07-2011 5:33 PM
Jojo
