Latency Graph
- Latency Graph
- « Previous
- 1
- 2
- Next »
Re: Latency Graph
21-02-2014 8:20 PM
Re: Latency Graph
21-02-2014 8:21 PM
Re: Latency Graph
21-02-2014 10:06 PM
Re: Latency Graph
21-02-2014 11:17 PM
There are two parts to making a connection, syncing with the exchange and logging in. It's the login/out aka PPP session that is safe to disconnect to get a new gateway multiple times.
If your router is PN supplied, at the Broadband Connection on the first page of its web interface you click Disconnect or Connect to safely get a new gateway and nothing else
Re: Latency Graph
22-02-2014 12:12 AM
(Gateway won't have anything to do with it unless we have a specific issue)
Ex-Broadband Service Manager
Re: Latency Graph
22-02-2014 5:19 AM
Re: Latency Graph
22-02-2014 5:22 AM
Quote from: Gus
I am using a Billion 7800DXL I will log into the router to see if I can find out where I login/out of PPP session. I'll give this a try
Re: Latency Graph
22-02-2014 1:11 PM
Quote from: goldenfibre Soft disconnection on the router will get u to different gateway
Will using a different gateway make a difference? Kelly seems to think it wont
Re: Latency Graph
22-02-2014 1:41 PM
So until I see constant red spikes on my TBB graph I won't gateway hop.
Re: Latency Graph
22-02-2014 1:44 PM
Re: Latency Graph
22-02-2014 3:20 PM
Quote from: greshoff My line went active about a week ago. Can you check if my Plusnet profile is set higher than my BT profile & if so what can be done to improve things
Your profiles are aligned correctly, I've just checked.
Re: Latency Graph
22-02-2014 4:15 PM
I usually check that list daily and they have been there for as long as I've been checking....
Re: Latency Graph
22-02-2014 6:49 PM
I have changed the gateway earlier on this afternoon and will post my graph tomorrow
Re: Latency Graph
22-02-2014 11:53 PM
Quote from: KevinAndrews This could be a wifi mobile device uploading photo or video.. this seems more intensive on the upload since the latest smart phones record in HD and create larger files and is most noticable on ADSL connections.
I believe iOS devices will update the Icloud backups if they're on WiFi and charging if Icloud is enabled, just a thought although going by the later posts it sounds like possible congestion somewhere in the BTW network.
Also did you remove your TBB test as i'm getting a not found error for the graphs
Re: Latency Graph
23-02-2014 8:30 AM
- « Previous
- 1
- 2
- Next »
