Latency Graph
- Latency Graph
Latency Graph
Latency Graph
20-02-2014 1:18 PM
Re: Latency Graph
Re: Latency Graph
20-02-2014 5:13 PM
On a Plusnet connection I wouldn't expect to see high latency spikes caused by downloads due to their QOS but this kind of graph could correspond with high upstream utilisation.
To solve that you would need to add your own upstream QOS into the mix.
Is it FTTC or ADSL?
Re: Latency Graph
Re: Latency Graph
20-02-2014 7:02 PM
Re: Latency Graph
Re: Latency Graph
20-02-2014 7:12 PM
You leave a pc active and something was active you don't know about
Someone in your house is online without you knowing it
Someone is leeching off your un-secure wifi
Re: Latency Graph
Re: Latency Graph
20-02-2014 7:15 PM
Re: Latency Graph
Re: Latency Graph
20-02-2014 7:19 PM
Re: Latency Graph
Re: Latency Graph
20-02-2014 8:58 PM
Re: Latency Graph
Re: Latency Graph
21-02-2014 9:17 AM
Re: Latency Graph
Re: Latency Graph
21-02-2014 6:22 PM
http://www.thinkbroadband.com/faq/sections/bqm.html
Also for dropped packets you are correct. Have a read of this:
http://revk.www.me.uk/2014/02/what-is-packet-loss.html
The yellow spikes aren't too much to worry about although a bit odd if you think nothing is using the connection.
The high yellow line can be caused by just one ping out of 100 in that time period being high as it is plotting the maximum. E.g. 99 at 10ms and 1 at 200ms.
Blue is the average response over 100 pings (One per second).
If this starts creeping up you are more likely to notice it while using your connection for latency sensitive things like gaming.
My bet is still on uploads for those big blue spikes. As Kevin says it could be something like an Ipad/phone backing up to icloud.
It's surprising what smart phones/tablets can get up to when you are not watching
Have you had your upstream uncapped by Plusnet?
When capped the upstream bandwidth is barely enough to cope with the ack packets from a 24 Mbps connection download.
Re: Latency Graph
Re: Latency Graph
21-02-2014 7:11 PM
Re: Latency Graph
Re: Latency Graph
21-02-2014 7:49 PM
Re: Latency Graph
Re: Latency Graph
21-02-2014 7:52 PM
Re: Latency Graph
Re: Latency Graph
21-02-2014 8:12 PM
Re: Latency Graph
Re: Latency Graph
21-02-2014 8:14 PM
Re: Latency Graph
Re: Latency Graph
21-02-2014 8:17 PM
