Laggy Browsing (plc-ag02)?
- Laggy Browsing (plc-ag02)?
29-12-2011 8:07 PM
Tracert also shows some slow and intermittent routing:
C:\Documents and Settings\User>tracert www.craigmurray.co.uk
Tracing route to craigmurray.co.uk [174.37.184.32]
over a maximum of 30 hops:
1 <1 ms 3 ms 3 ms 192.168.0.1
2 37 ms 36 ms * lo0-central4.pcl-ag02.plus.net [195.166.130.88]
3 38 ms 35 ms 38 ms 84.93.255.89
4 35 ms 35 ms 35 ms po4.pcl-gw02.plus.net [212.159.1.129]
5 38 ms 34 ms 35 ms 195.50.122.129
6 45 ms 39 ms 39 ms ae-52-52.csw2.London1.Level3.net [4.69.139.120]
7 35 ms 35 ms 37 ms ae-58-223.ebr2.London1.Level3.net [4.69.153.137]
8 100 ms 102 ms 103 ms ae-42-42.ebr1.NewYork1.Level3.net [4.69.137.70]
9 126 ms 117 ms 141 ms ae-91-91.csw4.NewYork1.Level3.net [4.69.134.78]
10 104 ms 104 ms 104 ms ae-4-90.edge3.NewYork1.Level3.net [4.69.155.209]
11 108 ms 103 ms 105 ms te2-5.bbr01.tl01.nyc01.networklayer.com [4.26.34
.22]
12 124 ms 124 ms 125 ms ae1.bbr01.eq01.chi01.networklayer.com [173.192.1
8.132]
13 127 ms 124 ms 125 ms ae7.bbr02.eq01.chi01.networklayer.com [173.192.1
8.171]
14 * * 167 ms ae1.bbr02.cf01.den01.networklayer.com [173.192.1
8.131]
15 152 ms 153 ms 149 ms ae7.bbr01.cf01.den01.networklayer.com [173.192.1
8.168]
16 177 ms 176 ms 178 ms ae0.bbr01.wb01.sea02.networklayer.com [173.192.1
8.144]
17 174 ms 173 ms 174 ms ae0.dar02.sr01.sea01.networklayer.com [173.192.1
8.159]
18 174 ms 176 ms 175 ms po2.fcr02.sr03.sea01.networklayer.com [67.228.11
8.227]
19 179 ms 176 ms 177 ms 174.37.184.32-static.reverse.softlayer.com [174.
37.184.32]
Trace complete.
Will try reconnecting to see if that does anything.
Re: Laggy Browsing (plc-ag02)?
29-12-2011 8:15 PM
30-12-2011 7:04 AM
30-12-2011 1:54 PM
news-europe.giganews.com
1 vl201.gw2.ams.giganews.com (216.196.110.2) 0 ms 0 ms 0 ms
2 216-196-108-178.ams.giganews.com (216.196.108.178) 0 ms
vl307.gw1.ams.giganews.com (216.196.108.242) 0 ms
vl305.gw1.ams.giganews.com (216.196.108.226) 0 ms
3 linx-gw1.plus.net (195.66.224.164) 7 ms 8 ms 8 ms
4 po5.pcl-gw02.plus.net (212.159.1.132) 7 ms 7 ms 9 ms
MPLS Label=1099 CoS=0 TTL=0 S=1
5 te2-1-620.pcl-gw01.plus.net (84.93.254.154) 7 ms 7 ms 7 ms
6 gi11-1-1-621.pcl-ag06.plus.net (84.93.254.136) 9 ms 8 ms 8 ms
7 * * *
8 * * *
9 * * *
Max number of unresponsive hops reached (firewall or filter?)
Lack of appropriate reverse-DNS entries for newly introduced gateway paths is the usual reason for that message. I expect Plusnet will add these in the New Year.
David
30-12-2011 2:21 PM
2 vl306.gw1.ams.giganews.com (216.196.108.234) 0 ms
3 linx-gw1.plus.net (195.66.224.164) 7 ms 7 ms 7 ms
4 po4.thn-gw1.plus.net (212.159.1.134) 7 ms 15 ms 7 ms
MPLS Label=127 CoS=0 TTL=0 S=1
5 po6.ptn-gw02.plus.net (212.159.1.137) 7 ms 7 ms 7 ms
MPLS Label=128 CoS=0 TTL=0 S=1
6 84.93.253.82 (84.93.253.82) 22 ms 16 ms 10 ms
7 * * *
8 * * *
9 * * *
Which doing an MTR the other way gives -
2. lo0-central5.ptn-ag04.plus.n 0.0% 10 21.9 23.2 20.9 32.7 3.5
3. 84.93.253.83 0.0% 10 59.4 24.8 20.5 59.4 12.2
4. po6.thn-gw1.plus.net 0.0% 10 144.2 41.1 20.1 144.2 39.9
30-12-2011 7:47 PM
I've added that to the list. The inbound path follows a different route from outgoing but it will still be ptn-ag04 (which is in Telehouse North).
30-12-2011 8:02 PM
2 vl304.gw1.ams.giganews.com (216.196.108.218) 0 ms vl305.gw1.ams.giganews.com (216.196.108.226) 0 ms 216-196-108-186.ams.giganews.com (216.196.108.186) 0 ms
3 linx-gw1.plus.net (195.66.224.164) 25 ms 7 ms 7 ms
4 84.92.6.180 (84.92.6.180) 7 ms 8 ms 7 ms
5 vl309.thn-gw1.plus.net (84.92.3.225) 8 ms 14 ms 9 ms
6 * * *
7 * * *
8 * * *
[code=MTR] 2. lo0-central3.thn-ag03.plus.n 0.0% 10 32.1 59.4 19.2 136.9 46.2
3. unknown.plus.net 0.0% 10 17.8 37.3 17.8 105.2 28.5 [/code]
30-12-2011 9:43 PM
30-12-2011 9:51 PM
30-12-2011 9:53 PM
Hopefully it stays that way!
30-12-2011 10:05 PM
I'm getting very variable speeds - now on pcl-ag02
30Dec11
http://www.mybroadbandspeed.co.uk
Today 21:49 255 kbps (31.9kB/s) 186 kbps (23.3kB/s)
Today 21:40 267 kbps (33.4kB/s) 237 kbps (29.6kB/s)
Today 21:13 16892 kbps (2.11MB/s) 1013 kbps (127kB/s)
Today 21:08 16582 kbps (2.07MB/s) 1013 kbps (127kB/s)
Today 21:07 16315 kbps (2.04MB/s) 1014 kbps (127kB/s)
Today 21:06 17024 kbps (2.13MB/s) 1013 kbps (127kB/s)
(rebooted router re-connected to the gateway known as pcl-ag02)
Today 20:25 267 kbps (33.4kB/s) 220 kbps (27.5kB/s)
Today 20:23 289 kbps (36.1kB/s) 167 kbps (20.9kB/s)
Today 20:21 15931 kbps (1.99MB/s) 241 kbps (30.1kB/s)
Today 19:49 270 kbps (33.8kB/s) 234 kbps (29.3kB/s)
Today 19:45 261 kbps (32.6kB/s) 235 kbps (29.4kB/s)
Today 19:44 413 kbps (51.6kB/s) 243 kbps (30.4kB/s)
Today 19:42 266 kbps (33.3kB/s) 239 kbps (29.9kB/s)
Today 19:40 254 kbps (31.8kB/s) 993 kbps (124kB/s)
Today 19:31 254 kbps (31.8kB/s) 233 kbps (29.1kB/s)
Today 19:29 262 kbps (32.8kB/s) 222 kbps (27.8kB/s)
Today 19:25 263 kbps (32.9kB/s) 173 kbps (21.6kB/s)
Today 19:23 255 kbps (31.9kB/s) 237 kbps (29.6kB/s)
Today 19:20 597 kbps (74.6kB/s) 1006 kbps (126kB/s)
(router connected to the gateway known as pcl-ag06)
Also http://www.speedtester.bt.com/ reports full connection speed ans does every time I run the test (hourly!!)
30Dec11
Download speed achieved during the test was - 10088 Kbps
Your DSL Connection Rate :19800 Kbps(DOWN-STREAM), 1187 Kbps(UP-STREAM)
Upload speed achieved during the test was - 975 Kbps
Upstream Rate IP profile on your line is - 1187 Kbps
Any ideas?
30-12-2011 10:23 PM
Just to add more timings - now on pcl-ag04.
Today 22:19 294 kbps (36.8kB/s) 219 kbps (27.4kB/s)
Today 22:16 16875 kbps (2.11MB/s) 293 kbps (36.6kB/s)
(currently connected to the gateway known as pcl-ag04
31-12-2011 1:27 AM
Quote from: purleigh And another one - ...
Thank you. I've added it to the list.
31-12-2011 8:20 AM
