Kitz Speed calculator says i should be getting a better connection?
- Kitz Speed calculator says i should be getting a b...
28-02-2016 2:10 PM
When putting in my stats on the kitz speed calculator http://www.kitz.co.uk/adsl/max_speed_calc.php
I get this:
Downstream Attenuation 25dbm, approx line length 1.8km
DSL MAX 8128kbps, ip profile 7150kbps
BT21CN WBC&ADSL 2+ 18144kbps IP Profile 16003kbps
From that I'm guessing that i should have an IP profile of 16Mbps which should give me a realistic performance of 15.5 ( or so ) Mbps which puts me roughly in line with what neighbours etc are getting ( 14-17mbps)
However im only getting about 10.5Mbps
The plusnet speed tester says this:
Estimated line speed: 11Mb (This may vary between 10Mb and 13.5Mb) - Checked on 2016-02-10 22:56:02
Current line speed: 11.2 Mb
BT speed test says this:
Download speedachieved during the test was - 10.6 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 11.3 Mbps
Upload speed achieved during the test was - 0.98Mbps
Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps
and from the router (TG582n) i get this
with router stats light reporting
Is this right? or shold i be getting a better speed/signal?
Is this because im using an old poor quality router ( TG582n) and would ther ebe an improvement if i purchased another router? or would i be wasting my money?
Bloke down the pub says I've been with the same company ( plusnet ) for too long and the equipment at the exchange may have gone stale (???) so i need to move to a new company that will put "fresh kit in the exchange" ( either after some sort of referal sign up or been drinking too much????)
I get this:
Quote Link Information
Uptime: 1 day, 23:51:03
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,163 / 12,803
Data Transferred (Sent/Received) [MB/GB]: 471.90 / 13.82
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 11.4 / 25.0
SN Margin (Up/Down) [dB]: 5.5 / 6.0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 703 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 95 / 4,350
HEC Errors (Up/Down): 154 / 10,162
Quote xdsl info expand=enabled
Physical Layer Statistics:
Modem state: up
Up time (Days hh:mm:ss): 1 day, 23:58:44
xDSL Standard: ITU-T G.992.5
xDSL Annex: Annex A
Channel Mode: Interleaved
Number of reset: 0
Chipset Vendor info (G.994.1): Local Remote
Country code: B500 B500
Specific: 0000 71C8
System Vendor info (showtime): Local Remote
Country code: 0F00 0000
Specific: 3C61 0000
Bearers generic info DS US
Payload rate [Kbps]: 12803 1163
Attenuation [dB]: 25.0 11.4
Margins [dB]: 5.9 5.6
Output power [dBm]: 0.0 12.8
Number of bearers: 1
Bearer 0 DS US
INP [DMT symbols]: 0.00 0.00
Delay [ms]: 0.14 0.24
Depth []: 1 0.00
R: 0 0
G.997.1 Statistics (Current):
Failures:
Line failures Near end
Loss of signal (LOS): 0
Loss of frame (LOF): 0
Loss of power (LPR): 0
Performance monitoring:
Line PM: Near end
Error second (ES): 707
Channel PM: Near end Far end
Bearer 0:
Code Violation (CV): 4354 95
FEC: 0 0
ATM data path PM: Near end Far end
Bearer 0:
HEC violation count (HEC): 10170 N/A
G.997.1 Statistics (last 15 minutes):
Failures:
Line PM: Near end
Error second (ES): 1
Bearer 0:
FEC: 0 0
Bearer 0:
G.997.1 Statistics (last 24 hours):
Failures:
Line PM: Near end
Bearer 0:
FEC: 0 0
Bearer 0:
{admin}
Message 1 of 7
(2,126 Views)
6 REPLIES 6
Re: Kitz Speed calculator says i should be getting a better connection?
13-03-2016 9:47 PM
I take it that this isnt worth bothering with.
Virgin media are busy digging away outside, starting to lay cables, that may be the better option when the time comes.
Message 2 of 7
(1,262 Views)
13-03-2016 11:23 PM
Quote from: pint Is this right? or shold i be getting a better speed/signal?
You would get better speed if you could reduce the number of errors being detected on your phone line.
Quote from: pint Is this because im using an old poor quality router ( TG582n) and would ther ebe an improvement if i purchased another router? or would i be wasting my money?
Those stats show that your TG582n is doing a pretty good job for the current line conditions, so until those errors are reduced, buying another router is unlikely to show any improvement in your sync speeds.
Quote from: pint Bloke down the pub says I've been with the same company ( plusnet ) for too long and the equipment at the exchange may have gone stale
Nope, you just have a noisy connection.
Quote from: pint so i need to move to a new company that will put "fresh kit in the exchange"
You would get similar results if you move to another ISP which uses BT supplied connections, however there is a chance that your sync speed might improve if you moved to an LLU (non-BT) internet service - as the line management is often less severe on LLU connections.
The first thing you need to try is moving the modem physically next to the "MASTER SOCKET", use the shortest RJ11 cable that you have to connect the modem to the "TEST SOCKET" (located behind the screw-on faceplate of your MASTER socket), and record the ADSL stats (as you did above), and see whether that shows an improvement.
Message 3 of 7
(1,262 Views)
13-03-2016 11:55 PM
The router/modem is connected to a mastersocket that looks like this
The RJ11 cable is 50cm long shielded cable that looks like this
from here: http://www.tandyonline.co.uk/electronics/telecoms-dsl/high-speed-rj11-dsl-cable-0-5m.html
I can unscrew all the Mk3 stuff and go straight into the test socket however that makes no difference.
Message 4 of 7
(1,262 Views)
14-03-2016 8:16 AM
Quote from: pint I can unscrew all the Mk3 stuff and go straight into the test socket however that makes no difference.
When you say it "makes no difference", do you mean to your speedtest results, or do you mean to the modem sync speed ?
It would be worth asking Plusnet staff to post in this thread, the graph showing your line connection/disconnections, to get an idea of how stable your broadband is, because from your stats I would say that having 707 errored seconds in under two days seems quite high but gives no indication whether they were dispersed or whether they happened all at the same time.
Message 5 of 7
(1,262 Views)
14-03-2016 8:32 AM
The 707 Errored Seconds over the 2 days makes the MTBE = (47*60*60+58*60+44)/707 = 244, which is reasonably acceptable, especially without any FEC+interleaving to correct errors.
It would only be a problem with the 582n if this particular one were faulty (or perhaps if its own power supply were chucking out a lot of interference).
Message 6 of 7
(1,262 Views)
14-03-2016 6:58 PM
with regards to connecting straight inot the mastersocket, no difference means no difference with speed/ performance/sync speed
latest stats
latest stats
Quote Uptime: 8 days, 8:39:45
Bandwidth (Up/Down) [kbps/kbps]: 1,163 / 12,691
Data Transferred (Sent/Received) [MB/GB]: 923.02 / 22.97
SN Margin (Up/Down) [dB]: 6.0 / 6.0
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 3,321 / 0
CRC Errors (Up/Down): 305 / 30,214
HEC Errors (Up/Down): 433 / 74,073
Message 7 of 7
(1,262 Views)
