Is my Bt wholesale profile stuck
- Is my Bt wholesale profile stuck
13-02-2014 6:42 PM
Router Stats:
Line Status:Connected
DSL Modulation Type:ADSL_2plus
Annex Type:Annex A
Upstream Downstream
Current Rate (Kbps) 1064 19784
Max Rate (Kbps) 1466 20448
SNR Margin (dB) 5 4.2
Line Attenuation (dB) 9.4 20.6
Errors (Pkts) 0 0
So I don't know what's happening.
(All test done over wired connection to router)
Re: Is my Bt wholesale profile stuck
13-02-2014 7:22 PM
Your ping graph shows a lot of horrible errors but this could well be due to the BT IP profile error
That just may also be the cause of the low speed test result
13-02-2014 8:02 PM
Ive raised a support question again, is their anything else i can do to get the BT side of it kicked? Also the errors shown on the ping test seem to be happening during the same period each day.
13-02-2014 8:06 PM
There isn't anything you can do but it will be picked up by the staff on here tomorrow
13-02-2014 8:08 PM
14-02-2014 11:32 AM
Please allow up to 24 hours for the change to take effect.
If the problem continues, please let us know so we can chase this further for you.
14-02-2014 7:52 PM
15-02-2014 5:07 PM
17-02-2014 1:45 PM
20-02-2014 10:43 AM
20-02-2014 11:36 AM
20-02-2014 12:23 PM
20-02-2014 2:07 PM
21-02-2014 4:39 AM
