IP Profile much lower than sync speed
- Re: IP Profile much lower than sync speed
15-07-2013 9:47 PM
I've just had a new broadband connection set up in my new property and after a while I was informed that the line speed was set to around 7Mb which I can confirm as my sync speed is indeed over 7Mb. However the BT IP profile speed has stuck at 2 Mb and has been at this level for at least two weeks, so my actual download speeds are being capped. Is there any way of forcing or encouraging the profile speed to increase in line with the actual sync speed. I thought htis was supposed to happen automatically but it seems to have got stuck.
Paul
P.S. please note this relates to our second Plusnet account.
Paul
Message 1 of 3
(711 Views)
2 REPLIES 2
15-07-2013 11:43 PM
Plusnet staff will have to get BT to unstick that profile. They might try to do that by resetting the line, which I believe sometimes works, sometimes doesn't. However the staff should be along tomorrow to take a look.
David
Message 2 of 3
(313 Views)
16-07-2013 1:38 PM
Can you PM your username over so I've got the right account and I'll take a look?
Message 3 of 3
(313 Views)
