I have to manually connect to the internet every time
- Re: I have to manually connect to the internet eve...
10-02-2016 9:46 AM
It's only been like this for the last week or so. I'm using a Thomson ST516. How do I set it so it automatically connects?
Message 1 of 4
(1,159 Views)
3 REPLIES 3
Re: I have to manually connect to the internet every time
10-02-2016 1:43 PM
Hi Zasps,
There doesn't seem to be a direct option in that modem's firmware to turn the ability to connect automatically on and off as it's designed to do that automatically.
I'd try a factory reset which should resolve this for you: http://www.plus.net/support/broadband/hardware/516v6.shtml
Message 2 of 4
(634 Views)
10-02-2016 5:36 PM
Thanks for that. It worked.
Message 3 of 4
(634 Views)
11-02-2016 4:50 PM
Message 4 of 4
(634 Views)
