How often is line speed updated
- Re: How often is line speed updated
22-01-2010 3:39 PM
I have had some issues with my adsl modem that casused it to drop connections and re-sync at lower speeds than the line was capable of, as a result my line speed has been downgraded by BT. I bought a replacement modem and have since be synced at a solid 6350 kbps so was wondering if and when my line speed would be increased to reflect the sync or do I need to disconnect\reconnect to force a change?
Thanks.
Thanks.
Message 1 of 8
(1,712 Views)
7 REPLIES 7
22-01-2010 3:46 PM
it should take about 3 days for the BT systems to trigger a change in tthe ipProfile and up to 12 hours after that for thr Plusnet system to catch up (they do it twice a day)
Message 2 of 8
(768 Views)
22-01-2010 4:40 PM
From my experience running a couple of bt speed tests speeds this up loads. Have you done any?
Message 3 of 8
(768 Views)
23-01-2010 8:58 AM
I haven't run any speed tests since noticing my line speed change but its got to be worth giving it a try.
Thanks for the info.
Message 4 of 8
(768 Views)
23-01-2010 9:04 AM
Just ran a speed test and yes it seems my line speed has been adjusted according to my new sync speed. Just waiting for the plusnet change now :).
Thanks.
Thanks.
Message 5 of 8
(768 Views)
25-01-2010 10:41 AM
Your speed profile on your side is showing as 5500 which matches the IP profile on our side, it updated Saturday afternoon.
Message 6 of 8
(768 Views)
25-01-2010 10:59 AM
Quote from: Oldjim it should take about 3 days for the BT systems to trigger a change in the ipProfile and up to 12 hours after that for thr Plusnet system to catch up (they do it twice a day).
The line profile script is only running once a day at the moment.
Message 7 of 8
(768 Views)
25-01-2010 11:16 AM
why - surely having to wait up to 24 hours for a speed increase isn't acceptable
Message 8 of 8
(768 Views)
