How frequently does your line drop ?
- Re: How frequently does your line drop ?
30-08-2007 1:57 PM
Am I normal ?
30-08-2007 2:01 PM
With Broadband you will experience the occasional drop, but not that often. Generally with an intermittent fault, you would expect to see multiple drops on a daily basis.
Is it inconveniencing you?
30-08-2007 9:43 PM
way through a long post on a web form when I forget to copy the text before clicking the submit button.
31-08-2007 11:47 AM
Make sure you provide some information about how often it drops though. Might also be an idea to see if something else is happening at the same time, such as hot water going on, street lighting and so on.
31-08-2007 12:37 PM
Regards .....
31-08-2007 12:48 PM
31-08-2007 4:53 PM
31-08-2007 8:51 PM
01-09-2007 8:40 AM
01-09-2007 2:39 PM
Plusnet Technology
04-09-2007 5:43 PM
My current situation: I've moved to a PlusNet Teleworker package with a new BT Voyager router. I used to have my router at the third node of a rather long phone line extension that meant I could have an upstairs network. I've now moved the router downstairs to the main BT socket and there's a wireless bridge to the small upstairs network.
My ADSL connection has been dropping several times a day just lately. However, I cannot track down whether this is a problem with my new broadband account or the fact that I have moved the router downstairs. I don't think there's a problem with the router itself, as it was working fine before I actually switched account towards the end of August. And I cannot understand how moving the router closer to the main BT socket could do anything but improve the connection. I guess I should go raise a ticket...
05-09-2007 2:56 PM
PlusNet support couldnt find anything wrong, but then how could they unless they ran their test just as my router dropped and before it reconnected as other than the fact my routers connection keeps dropping my broadband is fine.
05-09-2007 3:04 PM
The Faults Guys aren't actually saying that there isn't a problem. They're saying that the line tests that they have run aren't showing a specific problem, although you're obviously suffering from disconnections. They've said that if you still have an issue, they'll raise it with BT for you.
I'll pick up on that ticket now for you.
06-09-2007 1:26 PM
Quote from: James Hi there,
06-09-2007 2:15 PM
