Hardwired Bridge
- Hardwired Bridge
Hardwired Bridge
02-01-2013 3:01 PM
I need to find out the ip address and DHCP range ?
How do I do that for starers?
Donut
Re: Hardwired Bridge
02-01-2013 3:10 PM
You might prefer to buy a cheap bridge, which needs no configuration - if it's a wired only version.
Provided there is a router running DHCP, bridges are transparent to it.
(I paid £8 for mine, from Amazon)
02-01-2013 3:17 PM
If I buy a bridge to run from my router whatam I looking for.
I'm SERIOUSLY untechy so I wouldn't even know what to buy.
Cheers
Donut
02-01-2013 3:28 PM
02-01-2013 3:40 PM
I would like to plug a long lead into my main router , run this into another part of the house and stick an ariel on the end of it to use a laptop/internet radio there wirelessly.
Donut
02-01-2013 3:44 PM
02-01-2013 3:49 PM
this might help you get your head around matters http://www.unix.ms/netgear/
02-01-2013 3:55 PM
I have now managed to find the DHCP bit so will now have a play with it.
Would there be a problem in having the same SSID on the 2nd TG585 ?
Donut
02-01-2013 4:05 PM
02-01-2013 4:06 PM
02-01-2013 5:17 PM
Quote I have now managed to find the DHCP bit so will now have a play with it.
You will also need to change its ( the old router ) IP address since by default it will have the same one as the main router. Assuming the main router is at the default of 192.168.1.254 then set the old router to 192.168.1.63 i.e below the DHCP range of the main router ( assumed to be 192.168.1.64 to 192.168.1.252 ). The IP address setting should be on the same page as the DHCP settings.
04-01-2013 4:20 PM
So let me have a go at the method.
1. Change 2nd router static IP , disable DHCP , optional SSID change , Apply settings.
2. Connect 2nd router to main router using ethernet cable LAN to LAN.
3. Surf on 2nd router
Donut
04-01-2013 5:09 PM
Quote Is that the 'Static' IP I have to change?
Yes, its the one that currently is set to 192.168.1.254/24 Type Static ( assuming its similar to my TG582n ).
Best to do 1 in this order
Change SSID if required, Disable DHCP , Change Static IP
Since as soon as you change the IP you will lose communication with it.
You will need to use the new IP address to reconnect to its web gui if required.
04-01-2013 6:45 PM
I will give that a go.
Donut :0)
04-01-2013 7:35 PM
Thanx MrW,
Works a treat.
For some reason - and it doesn't stop it from working - the 2nd router doesn't show up on the 1st router ports - because its an xtension of itself?
But who cares , it works , now off to look for an internet radio.
Cheers
Donut
