Hardwired Bridge
Donut
Hardwired Bridge
Hi all I'm trying set up a hardwired bridge - if thats what its called - with an old router , trouble is I'm not very techy.  Sad
I need to find out the ip address and DHCP range ?
How do I do that for starers?
Donut
17 REPLIES 17
VileReynard
Fixes: 20
Re: Hardwired Bridge
You should (probably) disable DHCP.
You might prefer to buy a cheap bridge, which needs no configuration - if it's a wired only version.
Provided there is a router running DHCP, bridges are transparent to it.
(I paid £8 for mine, from Amazon)
Donut
How do I disable DHCP , I cant see it or know what it is.
If I buy a bridge to run from my router whatam I looking for.
I'm SERIOUSLY untechy so I wouldn't even know what to buy.
Cheers
Donut
jelv
Fixes: 10
Probably best if you explain what you are trying to achieve and what model the old router is.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Donut
In a nutshell and in laymans terms:
I would like to plug a long lead into my main router , run this into another part of the house and stick an ariel on the end of it to use a laptop/internet radio there wirelessly.
Donut
Fixes: 411
As Jelv says,  what make & model is the old router you plan to use for this ?
stallan
As the others have said, you need to say the makes/models of the devices you are using.
this might help you get your head around matters http://www.unix.ms/netgear/
Donut
TG585 V5 Thompson.
I have now managed to find the DHCP bit so will now have a play with it.
Would there be a problem in having the same SSID on the 2nd TG585 ?
Donut
ReedRichards
Seasoned Pro
Fixes: 25
Possibly.  I would try using a different SSID in the first instance.
stallan
I use the same SSID on both of mine but select different channels - been working fine for the last 2 years.
Fixes: 411
You will also need to change its ( the old router ) IP address since by default it will have the same one as the main router. Assuming the main router is at the default of 192.168.1.254 then set the old router to 192.168.1.63 i.e below the DHCP range of the main router ( assumed to be 192.168.1.64 to 192.168.1.252 ). The IP address setting should be on the same page as the DHCP settings.
Donut
Is that the 'Static' IP I have to change?
So let me have a go at the method.
1. Change 2nd router static IP  ,  disable DHCP ,  optional SSID change ,  Apply settings.
2.  Connect 2nd router to main router using ethernet cable  LAN to LAN.
3.  Surf on 2nd router
Donut
Fixes: 411
Yes, its the one that currently is set to 192.168.1.254/24 Type Static ( assuming its similar to my TG582n ).
Best to do 1 in this order
Change SSID if required, Disable DHCP , Change Static IP
Since as soon as you change the IP you will lose communication with it.
You will need to use the new IP address to reconnect to its web gui if required.
Donut
Thanx  MisterW ,
                              I will give that a go.
Donut  :0)
Donut
R lay loo yah!
Thanx MrW,
                      Works a treat.
For some reason - and it doesn't stop it from working - the 2nd router doesn't show up on the 1st router ports - because its an xtension of itself?
But who cares , it works , now off to look for an internet radio.
Cheers
Donut  Grin
