Fibre Broadband - Can I Use My Netgear N600 Modem
- Fibre Broadband - Can I Use My Netgear N600 Modem
22-04-2013 11:26 PM
It's a BT line version - not cable.
Also, has anyone noticed that the availability checker does not work? Well, it doesn't work for me. When I enter my land line number and postcode it just tells me the product I currently have and not those that I can switch to.
Thanks for your help.
Re: Fibre Broadband - Can I Use My Netgear N600 Modem
23-04-2013 9:18 AM
Quote Can I Use My Netgear N600 Modem if I upgrade to Fibre Broadband?
If it's this one http://www.netgear.com/home/products/wirelessrouters/high-performance/dgnd3700.aspx#two then yes, it has a Gigabit Ethernet WAN port.
23-04-2013 9:48 AM
23-04-2013 10:37 AM
Quote from: bazzer Also, has anyone noticed that the availability checker does not work? Well, it doesn't work for me. When I enter my land line number and postcode it just tells me the product I currently have and not those that I can switch to.
Odd
I though the line checker against a phone number was the "definitive" answer about what services were available on your line.
How do you know that you can upgrade to fibre on your line? - ie what was your source of info that you could upgrade and that FTTC is indeed available to you.
23-04-2013 10:55 AM
Yes, I assumed the OP meant could the N600 be connected to the BT supplied FTTC modem.
Quote As far as I can tell the one in the link is for ADSL2+ not vDSL, so if you actually meant the Modem rather than the Router part, MisterW made an error probably thinking you meant the Router part.
23-04-2013 12:43 PM
I didn't realise I would need two modems / routers. So my N600 will connect to the BT supplied modem.
With regards to the availability of Fibre, I received an email from Plusnet informing me that I could upgrade to Fibre. That's where I got the info from and not via the availability checker which is not working for me.
jim:quote
23-04-2013 2:04 PM
Fibre(FTTC) uses VDSL rather than ADSL. BT(Openreach) supply a VDSL modem when they do the installation and you need to connect a roouter to it using an Ethernet cable.
Quote I didn't realise I would need two modems / routers.
Just double check that yours actually has a WAN Ethernet port as shown in my link.
Quote So my N600 will connect to the BT supplied modem.
23-04-2013 2:33 PM
My router has a spare port at the bottom labelled Cable / Fibre.
jim:quote
23-04-2013 2:34 PM
Quote from: bazzer Thanks for the replies.
jim:quote
Out of interest what was modified and why? It looks like the original post I submitted.
23-04-2013 3:11 PM
Edit: update link
23-04-2013 3:46 PM
23-04-2013 4:06 PM
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
23-04-2013 4:57 PM
![Grin Grin](/html/@D40767E4EBB99989487344F3E42E44B1/images/emoticons/grin.gif)
One question though - can you advise why you didn't click on the link explaining the transgression
This isn't a dig at you as other have done, or rather not done, the same and I wonder if we need to think about rewording it or making it more prominent
23-04-2013 9:23 PM
I did click on the link but to be honest I didn't have the time to read through the extensive list of forum rules.
As a suggestion is it possible to direct the link to the actual rule that has been violated?
23-04-2013 9:54 PM
Will fix it
Done
