Download speed up during 'open questions', down again when closed
- Download speed up during 'open questions', down ag...
Re: Download speed up during 'open questions', down again when closed
27-05-2015 8:27 PM
27-05-2015 9:32 PM
28-05-2015 2:12 PM
28-05-2015 2:22 PM
Mick.
28-05-2015 9:11 PM
Once again, thanks for all the advice and help
Mick
29-05-2015 12:51 PM
No problem Mick, post some Stats when convenient and we'll see how it's going. Hopefully you are now going to have a good stable connection.
06-06-2015 12:51 PM
Anyway, here are the latest stats.
Here is the DSL information from today....
Link Information
Uptime: 4 days, 11:52:22
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 780 / 8.471
Data Transferred (Sent/Received) [MB/GB]: 178,01 / 4,68
Output Power (Up/Down) [dBm]: 12,2 / 20,4
Line Attenuation (Up/Down) [dB]: 24,0 / 44,5
SN Margin (Up/Down) [dB]: 5,4 / 6,3
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 18 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 885 / 0
FEC Errors (Up/Down): 182.246 / 156.928
CRC Errors (Up/Down): 0 / 667
HEC Errors (Up/Down): 0 / 12.025
BT Speed Test results (a bit disappointing)
Download Speed
4.35 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 4.35 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.47 Mbps
Upload Speed
0.49 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.49Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Current line speed....
Estimated line speed:
Current line speed:
7.4 Mb
I think that's all of it, isn't it? Its been a while since I ran a stat check!
Mick.
06-06-2015 1:46 PM
You've had 2 LOS since the firmware upgrade, have you rebooted at all?
One maybe possibly have been a line test. Otherwise, put into context, DS sync speed is par for the course, the US sync speed always has been a touch lower than one might hope for, but the errors look considerably better than the last stats.
Whilst that speed test was disappointing, try another - you may have just hit a moment when things were busy on the network, also how are you finding the connection whilst doing your normal usage?
06-06-2015 2:30 PM
Time Message
Info Jun 6 14:07:44 LOGIN User admin logged in on [HTTP] (from 192.168.1.74)
Info Jun 6 13:19:23 SNTP Synchronised to server: 212.159.13.50
Info Jun 6 12:41:36 LOGIN User admin logged in on [HTTP] (from 192.168.1.74)
Error Jun 6 12:39:43 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 207.86.156.45 Dst ip: XXXXX Type: Time Exceeded Code: Time to Live exceeded in Transit
Info Jun 6 12:19:23 SNTP Synchronised again to server: 212.159.6.9
Error Jun 6 11:36:33 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 188.165.216.87 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Info Jun 6 11:19:23 SNTP Synchronised again to server: 212.159.6.9
Info Jun 6 10:19:23 SNTP Synchronised again to server: 212.159.6.9
Info Jun 6 09:51:27 LOGIN wireless station [00:1c:bf:96:d4:06] can't get authorized.
Info Jun 6 09:31:27 LOGIN wireless station [00:1c:bf:96:d4:06] can't get authorized.
Info Jun 6 09:19:22 SNTP Synchronised again to server: 212.159.6.9
Error Jun 6 09:09:26 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 188.165.213.35 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Info Jun 6 08:31:28 LOGIN wireless station [00:1c:bf:96:d4:06] can't get authorized.
Info Jun 6 08:19:22 SNTP Synchronised to server: 212.159.6.9
Info Jun 6 08:11:36 CONFIGURATION mbus igd sync successfull
Info Jun 6 08:11:33 CONFIGURATION mbus atomic sync successful
Info Jun 6 07:19:22 SNTP Synchronised to server: 212.159.13.50
Info Jun 6 06:19:22 SNTP Synchronised to server: 212.159.13.49
Info Jun 6 05:19:22 SNTP Synchronised to server: 212.159.6.10
Info Jun 6 04:19:22 SNTP Synchronised to server: 212.159.13.49
Warning Jun 6 04:03:07 IDS scan parser : tcp syn scan: 92.39.52.203 scanned at least 20 ports at XXXXX. (1 of 1) : 92.39.52.203 XXXXX 60 53 TCP 51668->6003 [S.....] seq 1104413434 ack 0 win 29200
Info Jun 6 03:19:22 SNTP Synchronised to server: 212.159.13.50
Warning Jun 6 02:24:11 IDS scan parser : udp port scan: 5.189.145.240 scanned at least 20 ports at XXXXX (1 of 1) : 5.189.145.240 XXXXX 442 51 UDP 5064->5080
Info Jun 6 02:19:22 SNTP Synchronised again to server: 212.159.6.10
Info Jun 6 01:19:21 SNTP Synchronised again to server: 212.159.6.10
Warning Jun 6 01:12:48 IDS proto parser : tcp null port (1 of 1) : 123.151.42.61XXXXX 40 48 TCP 12207->0 [S.....] seq 1422811109 ack 0 win 8192
Info Jun 6 00:19:21 SNTP Synchronised to server: 212.159.6.10
Info Jun 5 23:19:21 SNTP Synchronised to server: 212.159.13.49
Info Jun 5 22:19:21 SNTP Synchronised to server: 212.159.13.50
Error Jun 5 22:00:11 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 61.129.63.62 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Info Jun 5 21:19:21 SNTP Synchronised to server: 212.159.6.10
Info Jun 5 20:19:21 SNTP Synchronised again to server: 212.159.13.49
Error Jun 5 19:41:32 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 151.80.9.128 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Info Jun 5
This is the first time I've looked at anything since the firmware upgrade, so I've done nothing to prompt router restarts, cold or warm. In fact due to my computer crashing this is the first time I've been using the internet to any extent in over a week.
Ookla gave me a download speed of 7 Mbps, Uswitch an upload speed of 0.6 Mbps, which is about normal since all the work done to move my router nearer the BT socket and to stabilise my connection. Ookla always displays the best download speed, and Uswitch the best upload speed. Performance online seems just as it was, from what I can see in my limited time back online. Prior to my computer having a nervous breakdown, I was trying to watch some cinema trailers on the Odeon listings website (other cinemas are available) and the trailers were freezing and jerking....totally unwatchable. Having said that, the same night my mate watched a full episode of Agents of S.H.I.E.L.D. on 4oD that he'd missed, on my computer, with no trouble, so apart from anything that my computer might have been doing with its impending meltdown, I assumed the sticky Odeon videos were down to the Odeon website.
06-06-2015 3:56 PM
You can check which Gateway you are on both before and after the hop.
Edit: sorry forgot to say, the limited size GUI log doesn't show anything of interest, the Telnet one may show that last drop but probably not worth looking at.
23-07-2015 10:44 AM
I've had two spontaneous ADSL disconnections in the last 12 hours, one while I was browsing the Internet, late last night (on my TV - I was too tired and too lazy to boot the computer) and one this morning while watching catch-up TV. So I've done a few stat readings to post here to see if anyone can pick up on anything, when they've got time. Unfortunately, because it has been a while since I've been on here and gone through this, I can't recall right this minute what the majority of the numbers mean again! Plus I have to get ready for work, as ever....
I took all the following readings BEFORE doing a controlled 'soft' disconnection and reconnection from within the Technicolor Router Gateway, less than half an hour ago. I did this because I found my download speed was okay, but my upload speed was poor, and I remember being told a soft restart can improve things - before sunset. Avoiding line noise and vampires. Unfortunately, at this time, the upload speed continues to be poor. By doing the controlled disconnection, I understand that my IP address will have changed, so I've not edited any of the details in the posted stats.
I just tried calling BT 17070 - that is the number for line tests, isn't it? They were engaged!!!
Anyway, my stats....
Recorded Events
Time Message
Jul 23 09:56:04 LOGIN User admin logged in on [HTTP] (from 192.168.1.81)
Jul 23 09:44:21 LOGIN wireless station [94:44:44:89:e5:e2] can't get authorized.
Jul 23 09:35:57 CONFIGURATION saved by TR69
Jul 23 09:35:40 PPP link up (Internet) [84.51.147.173]
Jul 23 09:35:39 PPP CHAP Receive success (Internet)
Jul 23 09:35:39 PPP CHAP Receive challenge from rhost JUNOS (Internet)
Jul 23 09:35:39 PPP CHAP Receive challenge from rhost acc-aln1.lmm (Internet)
Jul 23 09:35:30 xDSL linestate up (ITU-T G.992.5; downstream: 8193 kbit/s, upstream: 348 kbit/s; output Power Down: 20.4 dBm, Up: 12.0 dBm; line Attenuation Down: 45.0 dB, Up: 24.4 dB; snr Margin Down: 6.1 dB, Up: 5.0 dB)
Jul 23 09:35:17 PPP link down (Internet) [80.189.123.128]
Jul 23 09:35:02 xDSL linestate down
Jul 23 09:34:43 xDSL linestate down
Jul 23 09:24:11 SNTP Synchronised again to server: 212.159.6.10
Jul 23 09:16:25 CONFIGURATION saved by TR69
Jul 23 09:15:45 PPP link up (Internet) [80.189.123.128]
Jul 23 09:15:44 PPP CHAP Receive success (Internet)
Jul 23 09:15:42 PPP CHAP Receive challenge from rhost JUNOS (Internet)
Jul 23 09:15:41 PPP CHAP Receive challenge from rhost acc-aln1.lmm (Internet)
Jul 23 09:15:36 xDSL linestate up (ITU-T G.992.5; downstream: 8686 kbit/s, upstream: 636 kbit/s; output Power Down: 20.5 dBm, Up: 12.2 dBm; line Attenuation Down: 45.0 dB, Up: 24.3 dB; snr Margin Down: 6.3 dB, Up: 5.0 dB)
Jul 23 09:15:22 PPP link down (Internet) [146.198.134.9]
Jul 23 09:15:06 xDSL linestate down
Jul 23 09:14:47 xDSL linestate down
Jul 23 08:24:31 CONFIGURATION mbus igd sync successfull
Jul 23 08:24:26 CONFIGURATION mbus atomic sync successful
Jul 23 08:24:11 SNTP Synchronised again to server: 212.159.6.10
Jul 23 07:24:11 SNTP Synchronised again to server: 212.159.6.10
Jul 23 06:24:11 SNTP Synchronised again to server: 212.159.6.10
Jul 23 06:10:14 FIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 213.248.86.122 Dst ip: 146.198.134.9 Type: Time Exceeded Code: Time to Live exceeded in Transit
Jul 23 05:24:11 SNTP Synchronised again to server: 212.159.6.10
Jul 23 04:43:11 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 1.160.99.71 Dst ip: 146.198.134.9 Type: Destination Unreachable Code: Port Unreacheable
Jul 23 04:24:11 SNTP Synchronised again to server: 212.159.6.10
Jul 23 03:24:11 SNTP Synchronised to server: 212.159.6.10
Jul 23 02:24:11 SNTP Synchronised to server: 212.159.6.9
Jul 23 02:10:21 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 91.121.88.8 Dst ip: 146.198.134.9 Type: Destination Unreachable Code: Port Unreacheable
Jul 23 01:24:10 SNTP Synchronised again to server: 212.159.6.10
Jul 23 00:24:10 SNTP Synchronised again to server: 212.159.6.10
Jul 23 00:14:34 CONFIGURATION mbus igd sync successfull
Jul 23 00:14:29 CONFIGURATION mbus atomic sync successful
Jul 22 23:49:17 CONFIGURATION saved by TR69
Jul 22 23:48:59 PPP link up (Internet) [146.198.134.9]
DSL......
DSL Connection
Link Information
Uptime: 0 days, 0:22:33
Bandwidth (Up/Down) [kbps/kbps]: 348 / 8.193
Data Transferred (Sent/Received) [MB/GB]: 427,59 / 6,12
Output Power (Up/Down) [dBm]: 12,0 / 20,4
Line Attenuation (Up/Down) [dB]: 24,4 / 45,0
SN Margin (Up/Down) [dB]: 18,0 / 7,7
Loss of Framing (Local/Remote): 81 / 0
Loss of Signal (Local/Remote): 13 / 0
Error Seconds (Local/Remote): 6.371 / 46
FEC Errors (Up/Down): 8 / 634
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 0
Plusnet estimated line speed....
Current line speed:
7.5 Mb
BT line speed test results....
1. Best Effort Test: -provides background information.
Download Speed 3.83 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 3.83 Mbps
IP Profile for your line is - 7.23 Mbps
Upload Speed 0.25 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.25Mbps
Thanks for your attention, as ever.
Mick.
dick:green excessive spaces removed.
23-07-2015 3:19 PM
Quote I just tried calling BT 17070 - that is the number for line tests, isn't it? They were engaged!!!
That's very odd. Do you have problems making any other calls?
The rest of the line looks ok, can't see any obvious issues. The sync, attenuation and SNR seem fine, it's obvious the throughput that's lower than ideal.
23-07-2015 10:33 PM
Thanks for checking the figures, anyhow.
24-07-2015 8:06 AM
According to the stats, which I'm assuming were after you looked at the log, your DS sync speed is down marginally but as the SNRM at the time of the stats was slightly higher than 6dB a resync might resolve that BUT your US sync speed is HALF what it was and should be, and the SNRM is also proportionately high, again a resync may resolve this IF the source of the problem has gone away.
BUT when you look at the log entry it's clear there's been a further loss of sync between the log and the stats as the DS sync speed was nearer what it should be with the relevant SNRM, but the US sync speed was lower than normal with a lower than normal SNRM.
This all suggests (with the fact a further drop had also occurred) that issues were/are still present.
I would tend to wait until Western Power have finished their work, and assuming Openereach aren't poking around either, if the stats look similar, I would try a further graceful daytime resync.
It would be helpful if Chris could just post the current WBC profile so we are sure it is what we'd expect to see.
24-07-2015 9:30 AM
I bought the new surge protection block after the thunderstorms of a few weeks ago. I personally experienced no problems, but a lightening strike on a tree close to my mother and stepfather took out one of their telephones and their Sky Box, and tripped their power supply (and all of their neighbour's) and my old dad, who lives miles away, also lost his TV signal following the storms, but in his case it was an aerial amplifier plugged directly into a socket that failed, although it is not clear if it was on its way out anyway. His TV and DVD player were plugged into a surge protection block, and were okay, but the neon lights on the block had faded, as have mine - but they do that anyway through age. Those blocks that have a green light reckon that if the light is gone, there is no surge protection, which is why I've bought a new one. What confuses me is that some surge protection blocks only offer a 'power indication' lamp, or no lamp at all!
