Download speed up during 'open questions', down again when closed
- Download speed up during 'open questions', down ag...
Re: Download speed up during 'open questions', down again when closed
24-07-2015 9:37 AM
Let us know when you've fitted the new block, we'll have a look at what's happening.
24-07-2015 9:54 AM
24-07-2015 10:23 AM
Quote from: Anotherone It would be helpful if Chris could just post the current WBC profile so we are sure it is what we'd expect to see.
24-07-2015 4:02 PM
24-07-2015 4:04 PM
24-07-2015 4:21 PM
26-07-2015 9:53 AM
Yesterday (Saturday) I fitted my new surge protection block behind my stereo system and in doing so, shut down my router for about ten minutes. On re-booting it, I went straight to the BT Wholesale speed checker and got these results -
1. Best Effort Test: -provides background information.
Download Speed
6.59 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.59 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.75 Mbps
Upload Speed
0.56 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.56Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
I've just re-run the same test (Sunday morning) and got these results -
Download Speed
6.5 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 6.5 Mbps
IP Profile for your line is - 7.61 Mbps
Upload Speed
0.48 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.48Mbps
This was done wirelessly, but with me standing in front of the router, just a couple of feet away, to save me putting the ethernet lead in the back of my router, which is a bit tight to the wall and held there by concealed cables!
The latest round of other stats follow -
DSL Connection
Link Information
Uptime: 0 days, 6:21:20
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 756 / 8.629
Data Transferred (Sent/Received) [MB/MB]: 36,10 / 344,91
Output Power (Up/Down) [dBm]: 12,0 / 20,5
Line Attenuation (Up/Down) [dB]: 24,2 / 45,0
SN Margin (Up/Down) [dB]: 5,6 / 6,3
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 17 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 98 / 0
FEC Errors (Up/Down): 5.923 / 4.428
CRC Errors (Up/Down): 0 / 22
HEC Errors (Up/Down): 0 / 68
And here is my router log...
Recorded Events
Time Message
Info Jul 26 09:20:17 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info Jul 26 09:03:26 SNTP Synchronised to server: 212.159.6.10
Error Jul 26 08:23:13 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 122.202.178.232 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Info Jul 26 08:03:26 SNTP Synchronised again to server: 212.159.6.9
Info Jul 26 07:56:56 CONFIGURATION mbus igd sync successfull
Info Jul 26 07:56:52 CONFIGURATION mbus atomic sync successful
Error Jul 26 07:45:42 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 220.184.125.64 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Info Jul 26 07:03:25 SNTP Synchronised to server: 212.159.6.9
Info Jul 26 06:03:25 SNTP Synchronised again to server: 212.159.6.10
Error Jul 26 05:57:42 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 191.138.108.201 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Error Jul 26 05:56:38 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 69.69.152.231 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Error Jul 26 05:53:04 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 120.42.81.80 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Error Jul 26 05:50:45 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 179.171.169.25 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Error Jul 26 05:39:42 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 125.73.180.178 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Error Jul 26 05:32:27 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 222.142.97.178 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Error Jul 26 05:18:58 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 60.252.253.215 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Error Jul 26 05:12:20 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 69.69.155.192 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Info Jul 26 05:03:25 SNTP Synchronised again to server: 212.159.6.10
Error Jul 26 04:59:26 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 176.97.89.30 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Info Jul 26 04:03:25 SNTP Synchronised to server: 212.159.6.10
Error Jul 26 04:00:31 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 152.63.116.165 Dst ip: XXXXX Type: Time Exceeded Code: Time to Live exceeded in Transit
Error Jul 26 03:31:39 FIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 171.8.235.243 Dst ip: XXXXX Type: Destination Unreachable Code: Port Unreacheable
Error Jul 26 03:25:30 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 213.108.208.29 Dst ip: XXXXX Type: Destination Unreachable Code: Net Unreacheable
Info Jul 26 03:03:25 SNTP Synchronised to server: 212.159.6.9
Info Jul 26 03:00:16 CONFIGURATION saved by TR69
Warning Jul 26 02:59:58 PPP link up (Internet) [XXXXX]
Info Jul 26 02:59:57 PPP CHAP Receive success (Internet)
Info Jul 26 02:59:57 PPP CHAP Receive challenge from rhost PTN-AG01 (Internet)
Boy, obliterating my Dst ip from that list took some doing...it was only on there about a zillion times. I visited the optician yesterday - I think I need to go again now.
So, from my observations it would appear that I had another drop-out before I got out of bed this morning, although my upload speed issues seem resolved. The Ookla speed checker actually gave me 0.62Mb/s this morning, and that one is usually a bit slow on the up speed, good on the download speed. The work by Western Power contractors on the main road nearby is scheduled to be finished by tomorrow morning I think - the temporary traffic lights are still there at present, but the barriers that they had around holes in the grass verge on the entry road into my estate are now lying flat, so I think they've filled those holes in. What they've been doing and whether its had any effect on my internet experiences is open to speculation - when I peered into one of their holes, I could see some sort of grey plastic pipe, with a rectangular hatch in it. I've no idea if that is gas or electric. Do gas pipes have to be yellow?
Cheers,
Mick.
26-07-2015 5:09 PM
Well I guess we might all need to go to the optician after reading that log, I squinted several times, you obviously had fun editing it as you've manage to post the same section 3 times don't even worry about it. The stats are probably the most important thing at this point, they look near normal and the errors are nice and low, which considering the last resync (you've had 2 - LOS) was somewhere around 0330 if post time and uptime are anything to go by, is hopefully indicative of things being OK.
The GUI log doesn't shown the xDSL down and ups because of it's limited capacity and no doubt being filled with that spurt of ICMP checks 0500-0600ish! The Telnet log would show more, but not worth the effort of looking at this point, whilst Western Power and possibly Openreach are still poking about.
Once the holes are filled in and the work has ceased, watching what happens over the next couple of days will be the key. Speed tests as you know can vary, it's stats consistency we hope to see. If you can post some more stats later, and perhaps some tomorrow morning and evening, that may give a feel for how it's going. If you have any more sync loss, then the log could useful as well.
26-07-2015 8:02 PM
Here are a few Sunday night stats then - BT Wholesale.
Download Speed
6.57 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 6.57 Mbps
Upload Speed
0.46 Mbps
0 Mbps 0.83 Mbps
DSL stats -
Link Information
Uptime: 0 days, 16:58:29
Data Transferred (Sent/Received) [MB/MB]: 75,05 / 744,27
SN Margin (Up/Down) [dB]: 5,8 / 6,3
Error Seconds (Local/Remote): 119 / 0
FEC Errors (Up/Down): 16.914 / 11.268
CRC Errors (Up/Down): 0 / 50
HEC Errors (Up/Down): 0 / 190
I'm getting lazy again. The speed test was done upstairs wirelessly from the router downstairs - for a Sunday night, when I anticipate a lot of traffic, on a wireless connection, I think that 0.46Mbps upload speed is quite acceptable. A couple of days ago it wasn't achieving 0.3Mbps.
26-07-2015 8:12 PM
At least the rest looks good, the errors especially good, and you've had no more sync drops since last night.
26-07-2015 9:03 PM
09-08-2015 7:27 PM
So, I did the following tonight in this order - ran a couple of speed tests wirelessly (Ookla and Uswitch) and got good download speeds, poor upload speeds
logged into the Gateway, looked at the event log (nothing of interest)
took some DSL stats
disconnected the broadband connection from within the Gateway, waited three minutes, and reconnected
ran the Ookla and Uswitch tests as before, no improvement
put my ethernet lead between the PC and router, did a BT speed test, copied the result.
came on the forum.
I did the disconnection around 7pm, this being a Sunday, so the day is wearing on, but there is plenty of daylight left, whatever influence that has on results.
So here are the copied stats. Remember, the connection time (9 days) was before I did the disconnection at 7pm.
DSL Connection
Link Information
Uptime: 9 days, 6:32:56
Bandwidth (Up/Down) [kbps/kbps]: 396 / 8.520
Data Transferred (Sent/Received) [MB/GB]: 304,92 / 3,40
Output Power (Up/Down) [dBm]: 12,2 / 20,5
SN Margin (Up/Down) [dB]: 15,7 / 6,3
Loss of Framing (Local/Remote): 43 / 0
Loss of Signal (Local/Remote): 5 / 0
Error Seconds (Local/Remote): 1.158 / 94
FEC Errors (Up/Down): 6.202 / 512.333
CRC Errors (Up/Down): 6 / 1.294
HEC Errors (Up/Down): 8 / 14.014
Download Speed
6.2 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 6.2 Mbps
IP Profile for your line is - 7.52 Mbps
Upload Speed
0.26 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.26Mbps
All in all, I'd say my upload speed is pants, if I may be permitted to use that expression.
Mick
09-08-2015 7:59 PM
Quote from: mickthefitter I did the disconnection around 7pm, this being a Sunday, so the day is wearing on, but there is plenty of daylight left, whatever influence that has on results.
Hi Mick,
It is not so much the daylight which is the influence, rather continental AM radio interference travels further after dark and it is that which gives rise to degradation of xDSL operation.
Looks like your US needs to be uncapped.
Kevin
09-08-2015 8:02 PM
09-08-2015 9:55 PM
Quote Upstream Rate IP profile on your line is - 0.83 Mbps
