Disconnections Low SNR at Evening
ONeill
Re: Disconnections Low SNR at Evening
This is great, blood annoyed with plusnet and BT both are trying to fob me off, wished I stayed with O2/Sky  Cry
Had a normal BT engineer out not a REIN one that was requested, he did agree with me and that it is a REIN issue and my line is good, he did not know why he had to come when a REIN engineer should of come instead.
He tryed to book a REIN engineer to come out for me but was told by BT that they would have to fix my SNR at 9 first to see if it cures it but now I have a [Censored] sync rate and with multi people trying to use it, it's getting annoying  Angry
Even got told by plusnet support on phone to basically if what BT does fixes it then to lump what you have got, but he did not understand or care about the REIN issue/interference, gets worse when the BT engineer ran out of MK2 face plates  Angry
I wonder how much it would cost me to leave  Roll_eyes
Uptime: 0 days, 1:02:02
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 864 / 3,680
Data Transferred (Sent/Received) [MB/GB]: 38.09 / 1.12
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 32.7 / 53.0
SN Margin (Up/Down) [dB]: 8.8 / 11.9
Loss of Framing (Local/Remote): 17 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 138 / 2
FEC Errors (Up/Down): 3,167 / 528
CRC Errors (Up/Down): 31 / 9
HEC Errors (Up/Down): 102 / 45
Pettitto
Fixes: 5
Hi ONeill,
I can see that your Fault Ticket is still with our Faults Team ready for retested and for further review. A Faults Advisor will give you a call within the next few days to discuss this further with you. Unfortunately we cannot guarantee that a REIN Engineer will attend as there are so few of them around. It's important to note too that REIN investigation isn't something BT Openreach *have* to do, it's something they will investigate if they feel there is a REIN Issue.
I can't see any reason for further investigation to be carried out to get this looked at further. As I say, the Faults Team will be back in touch.
ONeill
What do you mean by  "I can't see any reason for further investigation to be carried out to get this looked at further", leave it as it is and lump it then  ?
Pettitto
Fixes: 5
Sorry, that was a typo.
I can't see any reason why we wouldn't investigate this further.
I appreciate your frustrated, I'll do what I can to help.
ONeill
No problem Chris  Wink
It is frustrating  Cry
In the middle of typing and it resyncs me even lower  Angry Cry
Uptime: 0 days, 0:00:27
Bandwidth (Up/Down) [kbps/kbps]: 864 / 3,513
Data Transferred (Sent/Received) [MB/GB]: 45.46 / 1.35
Line Attenuation (Up/Down) [dB]: 32.7 / 52.5
SN Margin (Up/Down) [dB]: 9.0 / 12.2
Loss of Framing (Local/Remote): 26 / 0
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 150 / 2
FEC Errors (Up/Down): 3 / 22
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
ONeill
Just had another resync, what the hell is going on  Roll_eyes
Uptime: 0 days, 0:01:07
Bandwidth (Up/Down) [kbps/kbps]: 866 / 4,731
Data Transferred (Sent/Received) [MB/GB]: 46.15 / 1.36
SN Margin (Up/Down) [dB]: 6.1 / 6.0
Loss of Framing (Local/Remote): 35 / 0
Loss of Signal (Local/Remote): 4 / 0
Error Seconds (Local/Remote): 160 / 2
FEC Errors (Up/Down): 7 / 20
Now waiting for the REIN interference so it can kick my SNR down to 0 and force me to restart again  Angry
On a side not that is similar to when I was on O2  Cheesy Grin
Fixes: 162
Hi ONeill,
What is happening here is you have a hard to locate source of noise which blasts your broadband to hell when it hits.  It will impact broadband regardless of who your ISP is.  BT will try to mask the problem by raising the target SNRM which is not ideal.  Chris has a lot of experience dealing with this BT strategy - work with him, but be prepared for this to take time.  My REIN issue took 6 months to resolve.
Kevin
ONeill
Will do Townman and I am not waiting 6 months of this hell just to fix it  Angry and I know what BT are playing at I just wish they would listen  Angry
Just done it again at 19:19 stats and graph of before and after added.
Got this when trying to ping again
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 192.168.1.254: Destination host unreachable.
Ping statistics for 8.8.8.8:
Connection could not be established: Could not bring up link
   Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Stats before restart
Uptime: 0 days, 2:59:43
Data Transferred (Sent/Received) [MB/GB]: 93.45 / 2.14
SN Margin (Up/Down) [dB]: 6.0 / 429496729.3
Error Seconds (Local/Remote): 589 / 2
FEC Errors (Up/Down): 6,993,630 / 12,362,087
CRC Errors (Up/Down): 5 / 20,843
HEC Errors (Up/Down): 5 / 1,012,181
Stats After Restart
Uptime: 0 days, 0:08:43
Bandwidth (Up/Down) [kbps/kbps]: 864 / 3,520
Data Transferred (Sent/Received) [kB/MB]: 326.18 / 1.96
SN Margin (Up/Down) [dB]: 9.2 / 6.0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 252 / 9,559
CRC Errors (Up/Down): 0 / 1
First bit of graph is BT and the exchange resyncing, will try and post another updated graph when I can.
ONeill
Some one managed to get a graph of it going back up, as you can see it goes up from about 6.5db to about 12.0db and checking just now it's sitting at 13.2db, so good for this fix at 9.0db  Shocked
Sync is still 3520 and as you know won't go back up until exchange boots me back up Sad
ONeill
Just another graph to add, this time it's gone from 13.0 dB to 6.6 db.
Update
Change the graph to a later one that shows it  going back up to 12.6 dB
Update
Just another graph to show it's fallen again, back to 6.3 dB
Fixes: 162
Quote from: ONeill
Slight confusion here - the SNRM is not fixed at 9dB, it will always be dynamic depending on the background noise.
Your TARGET SNRM has been fixed to 9dB - this means that on a resynch, you will get a synch speed which delivers a SNRM of 9dB over the then present noise and the DLM will not seek to ever adjust the TARGET.
The actual SNRM will then vary from that point due to the noise ceasing (SNRM rises) or commencing (SNRM falls) - actual SNRM is never static.
@DCT - from the graphs, there looks like a definite noise problem - is there any chance of actually getting a rein engineer on site?
Kevin
Pettitto
Fixes: 5
The Faults Team are due to pick this fault back up within the next 24 hours.
We'll try our best to get a REIN Engineer out, but as I say, it might take a while as there aren't as many REIN trained engineers as we would all like unfortunately.
ONeill
Thanks for getting back to me Chris  ;), I know there are not alot of REIN engineers out there, but I wish that BT would pull there fingers out  Roll_eyes
I just wish we can hurry and sort this problem out as being on this speed I'm getting my ear chewed off  Cry
Oh on a side note SNR is 7.0 dB and interference seems louder today, might just be the rain  Cheesy
ONeill
Got a reply from support the other day and going to send a REIN engineer, I did send them a reply but not sure if they got it, so can some one from DCT tell them I am available, This Friday, Saturday, Monday from 11:00AM - 18:00, but would like it saturday if possible.
Pettitto
Fixes: 5
We've got your response, our Faults Team will pick this up and book the engineer for you.
