Change the Router
- Change the Router
Change the Router
23-03-2012 6:19 PM
My broadband line disconects on rare occasions my neighbour as offered me a router which he as never used it is the same one that I have already got got and should I change all of the filters.
Message 1 of 3
(973 Views)
2 REPLIES 2
Re: Change the Router
23-03-2012 6:51 PM
I'd reccommend first swapping the router, keeping the old filters, and if you're still getting disconnects swap the filters. If you're still having problems remove all extensions and phones and plug directly into the test socket (if you have one). If you still see disconnects then you should raise a fault. If you see an improvement in the test socket then you know its your internal wiring and/or extensions.
If it only rarely disconnects though I'm not sure if it'l be seen as a problem, unless its affecting you're service.
Mike
Mike
Message 2 of 3
(432 Views)
26-03-2012 10:19 AM
Hi valart,
What router is it you are using? Can you tell me if you're using any extension cables/sockets? Do you have a test socket you can plug into?
Jojo
Jojo
Message 3 of 3
(432 Views)
