Broadband Speed
- Broadband Speed
Broadband Speed
10-11-2007 1:10 PM
Sorry folks yet another speed/set up query?!
I've just moved to BYW opt 2 and have get the following router stats:
Statistics Downstream Upstream
Line Rate 2912 Kbps 448 Kbps
Noise Margin 11.7 dB 19.0 dB
Line Attenuation 55.0 dB 31.0 dB
Output Power 18.1 dBm 11.9 dBm
The plus.net speed checker shows me at 1000.5 kps, while the broadbandchoices.co.uk shows me at 700kps
The speedtester.bt.com doesn't seem to be working for me today but it did show I should be able to see around 2000kps but was getting 800kps.
Any ideas if I can do anything to increase this?
I'm plugged directly into the main phone socket which has a filtered face plate, running a Voyager 2110 wireless connection.
Cheers all.
Cheers all.
Message 1 of 5
(1,517 Views)
4 REPLIES 4
Re: Broadband Speed
10-11-2007 1:39 PM
Just unplugged wire 8 from my main socket as I read only 2 & 5 are needed these days so now getting the following from my router:
Line Rate 3136 Kbps 448 Kbps
Noise Margin 12.3 dB 20.0 dB
Output Power 18.5 dBm 11.9 dBm
Noise margins seem to have gone up (doubt this is good ???) but the downstream line rate has increase?
Message 2 of 5
(519 Views)
Re: Broadband Speed
10-11-2007 1:54 PM
Please could you check and post your High-Speed Broadband value from the portal here.
This should be 2000kbps or hopefully 2500kbps if you've synced above 2848kbps for at least 3 days.
Secondly, if you are using Windows XP or earlier have you tweaked RWIN (and MTU)? Video help is available here.
Also have you checked for other devices (neighbours) using the same wireless channel? Trying the discrete channels 1, 6 and 11 might improve wireless throughput if that is a problem.
Since you've just re-synced it looks like your target noise margin is 12dB. Normally that would indicate the exchange monitoring equipment regards your line to be unstable. What variation in noise margin do you experience through the day (when it's dark particularly)? If sync speed drops at night due to lower noise margin that will cause your IP Profile and High-Speed Broadband setting (which mirrors BT's IP Profile) to drop in sympathy.
Edit: There is also the possible impact from network problems this morning, see Service Status here.
David
Message 3 of 5
(519 Views)
Re: Broadband Speed
10-11-2007 2:20 PM
Cheers for the reply,
I'm not overly techy when it comes to this so bear with me!
Synch speed is now showing as 2500kps (having previously been 1000kps) which must be good!
I'm in the process of checking the rest I'll let you know what I find out!
Thanks again!
Thanks again!
Message 4 of 5
(519 Views)
Re: Broadband Speed
10-11-2007 9:11 PM
Am I righting in thinking that plusnet speed test gives throughput speeds as does broadbandchoices.co.uk or so I believe.
Your router and bt speed tester give sync speeds.
The fact you got your sync speed up is good news. Would also recommend tweaking RWIN. Look into DrTCP if you do have XP.
Message 5 of 5
(519 Views)
