BT DLM Testing - List of accepted customers and profiles
- Re: BT DLM Testing - List of accepted customers an...
22-01-2010 12:55 PM
I've had the list back of the customers that have been selected to go on the trial and also a list of profiles that they are currently on. Some lines didn't make it on for a number of reasons including not enough data on the line or the line hadn't been used much, or the line was seen to be near enough perfect.
The list is below, the Current profile may look a little complicated but I'll split it up using mine as an example:
WBC 4M - 9M - downstream banding, if it's set to 160K - 24M then read it as no banded profile
Medium delay (INP 2) - downstream interleaving level, no delay = off, low = off, medium = on
6dB Downstream - downstream target SNR
448 - upstream speed - (448 or UC = uncapped)
Medium delay (INP 2) - upstream interleaving level, no delay = off, low = off, medium = on
6dB Upstream - upstrean target SNR
(ADSL2+) - access technology, will always be ADSL2+ for your lines
Next set of columns are what you all requested. Based on the profiles that are currently set let me know if you want to change.
The trial is set to start on Monday, I'll be putting in the changes I've got on most of the lines around Monday lunchtime and hopefully have them take effect Monday afternoon (your line should resync when the change is made).
The trial is set to last for 5 weeks finishing on 26th February. At the end of the trial everyone will have the option of staying on the profile they are on or switching back to normal and have DLM act as it does now. Do consider that if you stay on a fixed profile that if the line conditions change you may not benefit from a higher speed if it improves or you may see instability if it gets worse. We will be able to switch it back to normal DLM after the end of the trial, it just may take a little longer than during the trial.
We are allowed to make up to 1 change per line per day, we will also be getting line data on each line to be able to see how stable they are.
If something goes drastically wrong with a profile change then let me know either by posting here or sending me a PM (if you can't connect then call through to faults, let them know you are on the DLM trial and to pass a message on to me and I'll pick it up) and I'll do my best to change it back as soon as I can but it may be a next day change. For this reason I don't intend to make profile changes on a Thursday or Friday unless it is to back out a change that has gone wrong.
Are there any questions?
Username Current Profile Interleave Down SNR UPSNR Banded
Dave Tomlinson WBC 4M - 9M Medium delay (INP 2) 6dB Downstream, 448 Medium delay (INP 2) 6dB Upstream (ADSL2+) on 6 6 off
32110 WBC 160K - 24M Medium delay (INP 1) 15dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+) on 6 6 off
Barry Zubel WBC 3M - 6M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) off 6 6 off
chrisyoung WBC 7M - 14M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) off 6 6 off
Mav WBC 3M - 6M Medium delay (INP 2) 6dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+) off 6 6 off
deltec WBC 160K - 24M No delay (INP 0) 15dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) off 9 6 off
dannykos WBC 160K - 24M Medium delay (INP 1) 12dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+) off 6 6 off
Paul03 WBC 160K - 24M Low delay (INP 0) 3dB Downstream, 448 Medium delay (INP 2) 6dB Upstream (ADSL2+) on 3 3 off
scubarew WBC 160K - 24M No delay (INP 0) 15dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) off 6 6 off
grahamt WBC 160K - 24M Medium delay (INP 1) 6dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+) on 0 0 4864-9728
penfold WBC 160K - 24M Medium delay (INP 1) 15dB Downstream, 448 Medium delay (INP 2) 9dB Upstream (ADSL2+) on 12 9 off
Blackcurrant WBC 7M - 14M No delay (INP 0) 6dB Downstream, 448 No delay (INP 0) 6dB Upstream (ADSL2+) off 6 6 off
bluewhale WBC 160K - 24M No delay (INP 0) 15dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) off 6 6 off
spock WBC 160K - 24M No delay (INP 0) 12dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) on 6 6 off
carrot63 WBC 2M - 4M Medium delay (INP 4) 6dB Downstream, 448 Low delay (INP 0) 6dB Upstream (ADSL2+) on 0 0 3328-6656
Toenex WBC 160K - 24M Medium delay (INP 1) 6dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+) on 6 6 off
stallan WBC 160K - 24M Medium delay (INP 1) 12dB Downstream, UC Medium delay (INP 2) 9dB Upstream (ADSL2+) on 6 6 off
R WBC 160K - 24M No delay (INP 0) 12dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) off 12 6 off
Bojangles WBC 160K - 24M Medium delay (INP 1) 6dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+) off 6 6 off
whisky WBC 160K - 24M Medium delay (INP 1) 12dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+) off 9 6 off
Mad Moggies WBC 160K - 24M Medium delay (INP 1) 9dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+) off 3 6 off
ajbrown1965 WBC 4M - 9M Medium delay (INP 2) 6dB Downstream, 448 Low delay (INP 0) 6dB Upstream (ADSL2+) on 6 6 off
mvdb WBC 4M - 9M Medium delay (INP 2) 6dB Downstream, 448 Low delay (INP 0) 6dB Upstream (ADSL2+) on 6 12 off
adiewoo WBC 3M - 6M Medium delay (INP 2) 6dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+) on 3 6 off
Colin1 WBC 160K - 24M No delay (INP 0) 3dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) on 6 6 off
OrbitOne WBC 1M - 3M Medium delay (INP 4) 6dB Downstream, 448 Medium delay (INP 2) 6dB Upstream (ADSL2+) on 12 12 off
robr WBC 2M - 4M Medium delay (INP 4) 6dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+) on 9 6 off
Shaun2000 WBC 1M - 3M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 9dB Upstream (ADSL2+) off 6 6 off
walker23 WBC 3M - 6M No delay (INP 0) 6dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+) off 6 6 off
Be3G WBC 160K - 24M Medium delay (INP 1) 15dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+) on 6 6 off
Plusnet Technology
Re: BT DLM Testing - List of accepted customers and profiles
22-01-2010 1:13 PM
Also, could you set me on 9dB first please – considering that I'm currently on 15dB, I think jumping straight down to 6dB might be a too optimistic. If the line still copes with that fine (it used to vary between that and 6dB) then perhaps we can try 6dB later on.
22-01-2010 1:31 PM
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
22-01-2010 4:33 PM
[Edit: Doh! I wasn't reading the whole message thoroughly before I wrote the above paragraph. All these questions are, of course, covered in Dave's message. Sorry about that.]
It should be an interesting ride. In recent weeks I reckon my line has at last reached a stable, and maybe an optimum, setting (unbanded, target downstream SNR 6, syncing at 7974/805). It will be interesting to see what happens when it's put in the 4864-9728 band. Either there will be no difference, as the current settings are comfortably inside that band, or the DLM will try to set the line running at the upper limit, find that the line can't handle this and - well, I'm not sure.
The good thing is that if things get bad we can ask for a quick change.
Oh, one other question: I'm going to be away for a few days in the early part of the trial. Normally I'd switch the router off while I'm away, but would it be better to leave it on?
Graham
22-01-2010 9:29 PM
My line is certainly nowhere near perfect - but apparently it's not of interest.
22-01-2010 9:56 PM
23-01-2010 12:03 AM
23-01-2010 3:14 PM
Quote from: dave
at the end of the trial will we still be able to get you to change our fixed snr? or will we be stuck on that forever?
25-01-2010 1:19 PM
Quote from: grahamt Oh, one other question: I'm going to be away for a few days in the early part of the trial. Normally I'd switch the router off while I'm away, but would it be better to leave it on?
That's entirely up to you really, would be interesting to see how it performs when it's not being used, could be that it's different to how it performs when it's active. Less/no data will of course mean less/no errors on the line which is one of the things that causes DLM to make changes, so would be interesting to see if there are any losses of sync. etc.
Quote What's the point in ignoring users lines which are supposedly "too stable"?
Some lines have been running on 6dB/6dB no interleaving and have virtually no errors so because of limited slots available some of these were removed from the list, my test line in the office is one of them too.
Quote So will my SNR try to fix at 6 by varying the sync speed or will the target be set at 6 at some time with a fixed sync speed but variable SNR?
Like Be3G says the 6dB target SNR is aimed for whenever your line resyncs. So if it resyncs in the morning at say 4Mbps and then of the course of the day the SNR decreases in the evening you may be at 4Mbps with 3dB SNR. If it then loses sync it will resync and may resync at 3Mbps but at 6dB. Then assuming it doesn't lose sync again when you look at the router the following morning it could be sync'd at 3Mbps with the SNR being 9dB.
Quote at the end of the trial will we still be able to get you to change our fixed snr? or will we be stuck on that forever?
If you're on a particular fixed SNR profile at the end of the trial then we can either leave you on that one, change to another profile or go back to DLM as it is now. If you decide to stay on a fixed SNR then after the trial, until they roll this out as a live option, we'd only be able to change to having DLM switched back on rather than switch between the difference profiles.
The list is going in now and should hopefully have the changes take effect later today.
Plusnet Technology
25-01-2010 1:56 PM
25-01-2010 3:45 PM
Plusnet Technology
25-01-2010 3:51 PM
25-01-2010 5:07 PM
Unfortunately I needed to power down and back up again to reconnect.
Stats now are:
ADSL Link Downstream Upstream
Connection Speed 5385 kbps 1023 kbps
Line Attenuation 45 db 12.5 db
Noise Margin 6 db 6 db
although the DL NM seems to fluctuate between 3 & 6dB
Edit: Have just seen it as low as 2dB
Forum Moderator and Customer
25-01-2010 5:21 PM
25-01-2010 5:28 PM
Mine's done as well, was at 6827/440kbps now showing the following:
Downstream Upstream
Rate (Kbps): 7286 776
SNR Margin (dB): 3.9 9.6
Attenuation (dB): 52.5 27.4
Output Power (dBm): 12.9 0.0
Not had confirmation that the lines have all been done yet, I think they are working through them in order so Be3G your line will be the last one that gets done.
Plusnet Technology
