BB speed changing products
- BB speed changing products
13-09-2012 10:08 PM
I just had a qiuck look on the new residential products in the thought of changing because of the new home phone price increase. When I go through the steps it tells me what I am paying now and what I would be paying if I choose to swap. All that is clear, but the thing that is puzzling me is the download speed. My current D/L speed is classed as 10.5Mb/s, with a minumum of 8.5Mb/s and a maximum of 12.5Mb/s.
Now the new product says I will get an average speed of 7.5Mb/s. Is this figure arrived at because my line is deteriorating and if I do swap, then will this be my new average speed and I will get a new FTR of 5250.
As I see it, my speed at the moment of 8.2Mb/s is below the minimum average of 8.5Mb/s.
Message 1 of 4
(760 Views)
3 REPLIES 3
Re: BB speed changing products
13-09-2012 10:12 PM
It's probably a load of rubbish
If you go here https://portal.plus.net/my.html?action=data_transfer_speed and look at your estimated line speed it is probably the same
This is mine - not too accurate is it
Estimated line speed:
1.5Mb (Accurate to within +/- 1Mbit) - Checked on 2012-09-13 11:07:31
Current line speed:
4.3 Mb
Current line speed:
4.3 Mb
Message 2 of 4
(365 Views)
13-09-2012 10:21 PM
Not very accurate at all
10Mb (This may vary between 8.5Mb and 12.5Mb) - Checked on 2012-09-13 20:42:51
Current line speed:
8.9 Mb
Downstream Upstream
Data rate(Kbps) 11512 1219
Noise Margin 5 6
Output power(dBm) 12 20
Attenuation(dB) 29 16
I am starting to loose my faith in PN.
Current line speed:
8.9 Mb
Downstream Upstream
Noise Margin 5 6
Message 3 of 4
(365 Views)
14-09-2012 11:07 AM
I have replicated what you saw with the 7.5MB/s, this for some reason is showing you a 20CN profile. If you look to the right it will tell you your current line rate and states 10.5MB/s.
I will raise this with our web team to investigate. I can assure you that your speeds would be exactly how they are now if you were to change product, it would only be the product that would change.
Message 4 of 4
(365 Views)
