Another weird issue with a Netgear router
- Another weird issue with a Netgear router
01-01-2012 12:22 PM
In another post on a similar topic Oldjim states " when the error rate is so high that the signal is effectively borked the router should resync I have seen cases with a Dlink, Netgear and an old Speedtouch where it didn't and just sat there" .
Recently my packet loss gradually increased to 100%, Tbb monitor graph appended and eventually I lost connection and had to resync to get my connection back. I had forced my sync rate up by telnetting my noise margin down. Is this in effect the same thing? .Netgear DG 834Gv4 latest firmware.
My Broadband Ping
My Broadband Ping
Message 1 of 2
(790 Views)
1 REPLY 1
Re: Another weird issue with a Netgear router
01-01-2012 12:48 PM
You clearly pushed your connection too far in terms of the SNRM/sync speed it could reliably achieve (I have the same router and even pushing it close to rather than beyond a sustainable limit meant that any increase in sync was partly lost in terms of throughput due to the number of errors created.)
You router will have lost the forced SNRM after rebooting, and is probably best left to its and the exchange's own devices for the best compromise between reliability and speed.
Message 2 of 2
(352 Views)
