ANY ADMIN: Fault - Question #48964553
- ANY ADMIN: Fault - Question #48964553
22-11-2011 1:04 PM
I raised a fault and I have got a response back, could an Admin explain what is wrong with my line?
Message 1 of 4
(1,140 Views)
3 REPLIES 3
Re: ANY ADMIN: Fault - Question #48964553
22-11-2011 2:23 PM
I don't honestly think there's anything wrong with your line at all. Our faults team and our suppliers seem to agree which is why we could only recommend an SFI visit as the next step really.
You're on a 6.5mb profile. I can see that your connection on average drops about once per day, which isn't having any negative impact on your line.
I'm going to be straight up about this and ask you what you think is wrong with the line. I get the feeling from your frequent posts that you're striving for perfection in terms of getting the best out of your service and from our point of view you have a line that is stable and running at speeds which are indicative of line conditions and within the estimate we originally provided.
Message 2 of 4
(506 Views)
24-11-2011 11:25 AM
Thanks. I thought there was a fault because the line drops at night when it never used to on a 6dB margin. An engineer has been sent before and he fixed something but it doesn't seem to have helped.
Message 3 of 4
(506 Views)
24-11-2011 4:08 PM
The line dropping just the once, even if its on a daily isn't a fault. I can stick my neck out and say that as it will never have a negative effect on your connection, which is also operating within it's threshold rate and is otherwise stable.
It seems to me that you're striving for a service that never disconnects, unfortunately that is a very rare thing indeed. Some people are lucky to have that and unfortunately some don't.
As you probably know the DLM system is designed to lower speeds if the number of disconnections experienced reaches a level where it would otherwise serve to make the issue work, that certainly isn't happening at the moment so I'm confident in saying that your line is performing well.
Message 4 of 4
(506 Views)
