ADSL Speed is lower....
- ADSL Speed is lower....
- « Previous
- 1
- 2
- Next »
Re: ADSL Speed is lower....
24-11-2009 8:56 AM
Cheers,
Chris
24-11-2009 4:32 PM
Status: Up
Downstream Rate: 7776 Kbps
Upstream Rate: 448 Kbps
PVC Connection
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
QoS: UBR
PCR:
SCR:
Autodetect: Disable
VPI: 0
VCI: 38
Enable: 1
PVC Status: Up
From the downstream rate it has gone even lower than last night, I never had this before. I'm only a few hundred metres from the exchange and my phone line is clear...
Cheers,
Chris
26-11-2009 7:19 AM
26-11-2009 9:35 AM
Chris
26-11-2009 5:55 PM
--- System Information ---
Vendor: Linksys
ModelName: WAG320N
Firmware Version: 1.00.08 , 2009-08-27T19:37:13
Boot Version: 1.06
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 0/38
DSL Status: Showtime
DSL Mode: G.DMT
DSL Channel:
DSL Upstream Rate: 448 Kbps
DSL Downstream Rate: 8000 Kbps
Down up
DSL Noise Margin: 9.0 dB 24.0 dB
DSL Attenuation: 20.0 dB 9.0 dB
DSL Transmit Power: 19.8 dBm 12.1 dBm
Chris
26-11-2009 6:36 PM
Other thoughts, you haven't bought any new electrical equipment recently, or turned anything on you don't normally use? Or even next door neighbours likewise, or no nasty two stroke moped things been hanging around outside etc. Oh well, just thoughts.
27-11-2009 3:10 PM
I have installed a HTPC recently, connected by wireless so I don't think it's that, beside it's off when I'm doing my router checks. My phone line is as clear as a bell but we do have those pesky 2-stroke thingys racing up and down the road all of the time. Personally I blame them for everything, including the bad weather. Thus it won't take much more of an excuse before I string something cable'ish across the road, only kidding...
Cheers,
Chris
28-11-2009 5:58 AM
How about a stinger
28-11-2009 4:51 PM
Status: Up
Downstream Rate: 7808 Kbps
I think plusnet should sort it out, and quickly please, seeing as I have been at 8100 for years...
Chris
28-11-2009 8:16 PM
The sync speed will only go to 8128 if interleaving is turned off. You should still have a profile of 6500 at the moment.
If you aren't switching your modem/router off then you've had a sync drop (unless you rebooted for some reason!).
Edit: correct profile figure, incorrect value previously.
02-12-2009 8:08 PM
If this keeps on I'm out as the lack of a response or advice from +net is really begining to hack me off...
Chris
02-12-2009 10:55 PM
and check your PN one at the member centre - https://portal.plus.net/my.html?action=data_transfer_speed to make sure it matches and they are both 6500 as it won't be any higher with that last sync speed you posted on the 28th (I've corrected my post by the way, I quoted the wrong figure ).
What's bugging me is why you are getting these erratic connection speeds everytime you connect - this is not something that's controlled by PN, this is down to your equipment/wiring, the line to the exchange and the linecard at the exchange.
Have you had a listen to your phone line recently for any crackling or other intermittent noises? Dial a 1 to get rid of the dial tone. If you need more time before the NUT (number unobtainable tone) dial the quiet line test 17070 option 2. (Don't use any ringback or other test). Who is your Telephone Line Rental provider?
Could you give an Outline description of your installation -
1) Do you have an NTE5 Master LineBox (the type with the removeable lower front plate) and which logo it has on it.?
2) Whether you have any fixed extension wiring and sockets & how many, and roughly how the cables go from one to another;
3) What filters do you have and where is the Modem/Router plugged in?
4) Do you have a corded phone, do you have a cordless phone - if so what type - DECT or Analogue?
5) Is any other POTS (plain old telephone service) equipment (Faxes, Answer phones, Sky boxes or Alarms systems etc) plugged in/connected?
- « Previous
- 1
- 2
- Next »
