51db adsl /adsl2 compare
- Re: 51db adsl /adsl2 compare
17-05-2009 11:47 AM
I think you said elsewhere that interleaving was off, it might be worth trying with it on to see whether that helps. Or possibly one of the increased stability options that Fletch mentioned here, though I'm not aware of any follow up from that post.
David
17-05-2009 4:59 PM
might save you having to resync your line.
17-05-2009 5:52 PM
22-05-2009 8:46 PM
[smug mode]
Quote from: ASBO BTw can stick this new DLM where the sun dont shine.
3072 @ 18db all because i was getting noise spikes yestarday most likely due to a thunderstorm. so i pegged my speed back with dmt tool to 13db to get just over 3500 sync which got errored seconds down from 100 every 15mins to 2 every 15 mins.
i thought great tomoro i can resync back to 4544 again when noise spikes had gone.
nah DLM had other ideas and droped my line at 10am even tho my line was stable for 12 hours if the graph was on a hospital heart monitor they would be pronounced dead it was that flat and stable
Noise Margin: 6.0 dB
Connection Rate: 4000 Kbps
Line Attenuation: 52.0 dB
Total Up Time 4 days, 23:02:30
[/smug mode]
22-05-2009 11:21 PM
my router is having some police line do not cross tape round it tomoro and if the DLM dosent drop my line and resync with 4544 9db within a weeks uptime then you can stay in smug mode intill your forced on to BTw's 21cn
p.s does bbc iplayer HD play o.k on 3500 profile or does it still stutter?
24-05-2009 11:17 AM
25-05-2009 5:58 PM
DLM droped my line this morning and came back up with a 15db target instead of 18db ( all ways happens at 9.50am-10.00am every time it drops or raises my noise margin)
25-05-2009 6:34 PM
this last drop from 18 to 15db looks like it took bang on week to drop the target
26-05-2009 12:31 AM
i can now sync like i did on adsl at about 6pm ish to set bitloading up on fastpath for night time noise levels
27-05-2009 10:52 AM
19-10-2009 12:11 AM
Which i got released from a week ago and was left on 15db target noise margin. Bang on midnight its just droped me down to a 12db noise margin. (which made a game of operation flashpoint i was hosting come to an end and being bang on midnight i was screaming murder towards plusnet till i came an checked routerstats )
hopefully the DLM stays at this noise margin and leaves my line alone now ( guess what bang on the same as adsl ran stable at on my line) its only taken since april the 7th for the DLM to learn my line
25-11-2009 12:42 PM
why o why o god dam why
EDIT. think am going to do a resync during the night to try and get that sync as close to the 3000kbps profile sync theshold
25-11-2009 5:05 PM
just nipped out and when i came back couldnt get any net. tried pinging the pcl gateway and was getting bucketfuls of packet loss. so i scratch my head before looking at the below graph.
note to the DLM if it anit broke dont fix it.
just gave it reboot and its only gone down to 4000kbps so am going to give dmt a twirl and gentely raise the noise margin some
EDIT. cheers anotherone for puting out i had put lower margin instead of raise
25-11-2009 5:18 PM
25-11-2009 5:23 PM
re edited the above es graph to make the times at the bottom visable
