20Mhz or 40Mhz
- Re: 20Mhz or 40Mhz
20Mhz or 40Mhz
01-09-2010 3:08 PM
My router has 2 settings 20Mhz or 20/40Mhz. The default setting is 20Mhz.
I bought a new D-link 2740R which had 20Mhz or 40Mhz and the default on that one was 40Mhz.
What's the difference (and don't say 20Mhz!!) and which mode should I choose.
Message 1 of 5
(4,943 Views)
4 REPLIES 4
Re: 20Mhz or 40Mhz
01-09-2010 4:00 PM
Hi julesandsand,
As far as I know these frequencies relate just to the wireless connection. 40 Mhz will give you a wider bandwidth which can be prone to more interference and 20 will obviously be less bandwidth but less prone to interference. This is the black and white answer and there are probably a lot more reasons whether you would use one or the other, depending on whether you were running various machines on your network. All that said, probably the best way to find out is to try each one and see what the performance is like.
Jojo
Jojo
Message 2 of 5
(896 Views)
Re: 20Mhz or 40Mhz
01-09-2010 4:14 PM
Hi Jojo,
Thanks for that. I've got loads of things attached to my network. I don't think I'll mess about with it - had a bad week with routers!
Message 3 of 5
(896 Views)
Re: 20Mhz or 40Mhz
01-09-2010 4:21 PM
Don't blame you really but I've just googled '20mhz or 40mhz' and there's quite a bit of info out there if you get the time or the patience.
Jojo
Jojo
Message 4 of 5
(896 Views)
Re: 20Mhz or 40Mhz
01-09-2010 5:38 PM
There certainly is, I found this useful,
http://www.dd-wrt.com/wiki/index.php/Wireless-N_Configuration
Message 5 of 5
(896 Views)
