Any chance of a delete button
techguy
So you can delete your post if it doesn't make sense?
25 REPLIES 25
geewizz
Re: Any chance of a delete button
Use the preview button. It takes the same amount of time, you just need to change the order you do things in.
techguy
Thanks for that geewizz but my suggestion is simply if you do go that extra step, re-read the thread and want to remove your post.
Fixes: 1,492
There did used to be a delete button, but it was removed after misuse.
Just edit your post out and put it didn't make sense.
Oldjim
Resting Legend
Fixes: 63
Alternatively - if you really want it removed - click on the report to mooderator link and request removal.
We can't delete it but we can remove it from public view
community
OOPS wrong thread.....
techguy
No all I was asking for was a delete button for your own posts.
Oldjim
Resting Legend
Fixes: 63
and the reply by addiewoo covered that.
It was before your time I think but a user deleted all his posts which really messed up a lot of threads
techguy
Sorry, thought that community thought I was making a bid for moderation  Smiley
community
Sorry, I should explain that my "OOPS, wrong thread" referred to a reply to another thread I had just typed and sent...but to the wrong thread and there was no way of deleting my comments.
cheers
LATER : having just read my above, if you understand what I wrote, you're a genius . I should have more lessons in writing good english!  Smiley
pjmarsh
Fixes: 24
Quote from: Oldjim
You can't report your own posts can you?  Or has that changed?
Phil
Edit:  Just tried it, and it doesn't work.
jelv
Fixes: 10
You could change the message to contain some profanities that are sure to get someone else reporting it to the moderators.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
Quote from: pjmarsh
Quote from: Oldjim
Phil
You learn something every day  Embarrassed
Alex
Fixes: 13
Yes, I remember it being removed.
I can't remember the last time I needed to remove one of my posts, but I guess you can always edit the text to 'removed' .. or something like that. I don't seem to get it on these forums now, but on the old phpBB forums I used to often accidentally make a duplicate post and it was handy to be able to remove the second one.
Thing is though, if someone were to edit all their posts and remove all content, then that would mess up threads as well. Not as much as if the post was removed, but you still wouldn't know what people were replying to.
pjmarsh
Fixes: 24
At least you would know something had been going on though.  If I remember right, when the incident happened and someone deleted a load of their own posts, it got very confusing as it wasn't obvious that the deleted post ever existed.
Phil
