Fibre Installed : Speeds not as I expected
- Fibre Installed : Speeds not as I expected
17-07-2012 8:16 PM
I was told (by someone from PN as far as I remember) that the cabinet that serves the property is around 120m away by road according to google (but OR guy said about 60m). Isnt the attainable rate a little low if the cabinets around 120m away? (Even if it took a non-straight route, it cant stem out more than 200m).
Could it be that the cabinet is actually an ECI-based cab, and ive been given a Huawei modem? (I vaguely remember reading all Phase 6 cabs would be ECI on a Openreach PDF). - Or could it be the line is still in 10 day training mode?
I raised a ticket expressing interest in the 80/20 trial too, going to see how that goes aswell.
Any help would be awesomeness
Cheers
Re: Fibre Installed : Speeds not as I expected
17-07-2012 9:03 PM
Is the FTTC cab close to the old cab (you need to add the distance between the cabs)?
Can you get the Attenuation table out of the modem?
AFAIK Huawei modems perform perfectly well on ECI cabs.
There's a lot of info on the ThinkBroadband forums regarding speeds, distances, attenuation etc. Also worth searching for posts by 'Bald_Eagle1' who has produced some excellent graphing scripts for this modem.
17-07-2012 10:14 PM
Old cab i think is around 75cm away from the new one, so 120.75m. Stats page is attached, im trying to get the Line Attenuation values via Telnet but i have no clue how!
17-07-2012 10:21 PM
[Edit] Memory's still a bit hazy, once you log in using telnet I think you need to type sh, once you're in the specific command is xdslcmd info --pbParams
Here's an example: http://community.plus.net/forum/index.php/topic,105351.msg898997.html#msg898997
18-07-2012 9:05 AM
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 18545 Kbps, Downstream rate = 55348 Kbps
Path: 0, Upstream rate = 1999 Kbps, Downstream rate = 39998 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 18545 kbps 55348 kbps
Actual Aggregate Tx Power: 2.7 dBm 13.1 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 4.4 24.0 36.2 N/A 12.0 29.9 46.4
Signal Attenuation(dB): 7.1 23.0 34.2 N/A 12.0 29.9 46.4
SNR Margin(dB): 20.5 20.4 20.3 N/A 10.8 10.8 11.0
TX Power(dBm): -4.3 -19.9 1.6 N/A 10.3 7.8 5.9
EDIT: Have a look at the map for an illustration of where the telegraph pole and line enters the house to where the fibre cab is. Was told on this thread: http://community.plus.net/forum/?topic=99554.msg843559 that the cab is the one down on the junction of Essex Road.
18-07-2012 10:23 AM
Your profile is 40MB/s D/L and 2MB/s U/L, so 34/35MB/s is acceptable, although your achievable speeds on your line are both higher on the D/L and U/L than you are currently getting. Your profile is not set up for these speeds, however when you have moved over to the 80/20 trial then you will see the speed increase on your connection to your attainable speeds, possibly faster.
Your modem is showing you your attainable rate what it is at the moment, but the only way we will know if your going to achieve faster than the attainable rate is when you are on the 80/20 trial. Certainly the quality and route of the line can also have a bearing on your attainable speed.
Chris
18-07-2012 10:33 AM
Is there any way of checking if the line is alumium or copper? (Without taking the master socket apart and finding the dropwire?)
dial tones always been clear and the line going from the house to the pole is in quite good condition, and according to the engineer, the line apparentley takes a direct route from the telegraph pole (which is right outside the property) to the cab.
18-07-2012 11:16 AM
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 16395 Kbps, Downstream rate = 46760 Kbps
Path: 0, Upstream rate = 16428 Kbps, Downstream rate = 48511 Kbps
Attainable Net Data Rate: 16395 kbps 46760 kbps
Actual Aggregate Tx Power: 6.8 dBm 12.7 dBm
Line Attenuation(dB): 5.4 29.7 44.9 N/A 14.5 36.4 56.3
Signal Attenuation(dB): 7.2 28.9 43.8 N/A 14.5 36.4 56.3
SNR Margin(dB): 6.0 6.2 6.2 N/A 5.3 5.3 5.4
TX Power(dBm): -4.1 -13.1 6.3 N/A 9.8 7.8 5.1
So I'd possibly question either your line length or quality, I'd certinly recomend having a look here: http://forum.kitz.co.uk/index.php/topic,10552.0.html
18-07-2012 11:47 AM
I'd just leave your line alone for the moment and monitor it to see what it becomes stable at.
18-07-2012 12:20 PM
I've even got Stainless steel plumbing!!!
18-07-2012 12:38 PM
Edit: Oh, and the attenuation is 0dB, so you wouldn't get any better if the cab was in your front garden!
18-07-2012 12:54 PM
And the 0db attenuation: Its a bug in the UI, not the real value! The real line attenuations in the code thingybob I posted before.
18-07-2012 1:20 PM
Out of curiosity what did the BT speedtester give for the Upload speed?
This page has some interesting info. At 200m estimated max. is 65Mb/s
18-07-2012 1:34 PM
18-07-2012 2:00 PM
