Cannot open ports on TG585 v8 router
- Cannot open ports on TG585 v8 router
01-08-2012 8:28 PM
Product Name: TG585 v8
Software Release: 8.2.7.8
Hi, I am trying to open the port 12933. I turned broadband firewall off, restarted and port still remains closed when i checked with a few port chicking websites. I have done it before and it used to work but not anymore. Maybe i forgot how to open ports correctly. Can someone please let me know how to open and/or forward ports on TG585 v8 correctly?
Message 1 of 6
(1,347 Views)
5 REPLIES 5
Re: Cannot open ports on TG585 v8 router
01-08-2012 8:31 PM
I had the same issues with my TG585 V8 so went back to using my V7 router. That worked with no issues. I just thought it was me being dull
Message 2 of 6
(523 Views)
01-08-2012 8:33 PM
you are right, i think i had v7 when it used to work...
I checked with pfportchecker and it seems to be open, useless port checking websites :o..
Message 3 of 6
(523 Views)
02-08-2012 9:15 AM
When logged into the config page go to "Home Network" then select "assign a game or application to a local network device", then add, following that enter the same port number into the port range boxes, leaving trigger port blank, the rest should be fairly self explanatory but let us know anyway if you have any issues.
Adam.
Adam.
Message 4 of 6
(523 Views)
02-08-2012 11:59 AM
thanks for the reply, i set opened the prot but the program i am using only works with hamachi or vpn passthrough tunnel which i am currently wanting to set up. If anyone can help please check my new topic made today.
Message 5 of 6
(523 Views)
02-08-2012 3:02 PM
Message 6 of 6
(523 Views)
