Internet interruptions / Router Reboots. ? Problem
- Internet interruptions / Router Reboots. ? Problem
22-01-2012 1:22 PM
looking at the router logs it seems like it is rebooting for some reason. Does anyone who knows more than me about these logs see a problem in the following?
00:02:26 (since last boot) UPnP action 'AddPortMapping' from ip=192.168.1.71 (Success)
00:02:25 (since last boot) UPnP action 'AddPortMapping' from ip=192.168.1.71 (Success)
00:02:24 (since last boot) UPnP action 'DeletePortMapping' from ip=192.168.1.71 (No such entry in array)
00:02:22 (since last boot) UPnP action 'DeletePortMapping' from ip=192.168.1.71 (No such entry in array)
00:01:52 (since last boot) UPnP action 'DeletePortMapping' from ip=192.168.1.71 (Success)
00:01:51 (since last boot) UPnP action 'AddPortMapping' from ip=192.168.1.71 (Success)
00:01:33 (since last boot) UPnP action 'DeletePortMapping' from ip=192.168.1.65 (Success)
00:01:33 (since last boot) UPnP action 'AddPortMapping' from ip=192.168.1.65 (Success)
00:01:02 (since last boot) PPP link up (Internet) [81.174.240.75]
00:01:02 (since last boot) FIREWALL event (1 of 6): deleted rules
00:01:01 (since last boot) GRP Default destination is routed via gateway 81.XXX.XXX.75
00:01:02 (since last boot) PPP CHAP Chap receive success : authentication ok
00:01:02 (since last boot) PPP CHAP Receive challenge (rhost = pcl-ag05)
00:01:01 (since last boot) PPP CHAP Receive challenge (rhost = ERX15.Ilford4)
00:00:43 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 8128 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 25.0 dB, Up: 13.5 dB; snr Margin Down: 9.0 dB, Up: 24.0 dB)
00:00:26 (since last boot) LOGIN User Administrator logged in on [HTTP] (from 192.168.1.71)
00:00:26 (since last boot) DHCS server up
00:00:26 (since last boot) FIREWALL event (1 of 1): deleted rules
00:00:26 (since last boot) FIREWALL level changed to Standard.
00:00:22 (since last boot) FIREWALL exact tcp state check (1 of 1): Protocol: TCP Src ip: 192.168.1.71 Src port: 57878 Dst ip: 64.4.34.104 Dst port: 80
00:00:16 (since last boot) FIREWALL event (1 of 1): modified rules
00:00:16 (since last boot) FIREWALL event (1 of 1): created rules
00:00:04 (since last boot) WIRELESS interface turned on.
00:00:03 (since last boot) [CWMP: 0:00:02.810] setting cwmp defaults
00:00:02 (since last boot) KERNEL Warm restart
PT
Re: Internet interruptions / Router Reboots. ? Problem
22-01-2012 2:28 PM
22-01-2012 2:38 PM
Could it be one of the new devices we got at xmas causing a problem - new laptop, ipod touch and sony internet TV? although I think I can rule the TV out because it does it when its off.
22-01-2012 2:52 PM
David
22-01-2012 3:05 PM
Quote from: spraxyt This problem may be related to the new laptop. The library article Fixing Wireless Compatibility Problems with the Thomson 585v8/ suggests things to check and try. Though the article is TG5585v8 related It's possible the problem also affects the v7.
David
thanks. the router is only on b/g anyway and the adapter is not intel. adhoc N was already disabled.
I wonder if the router gets warmer coping with so many devices. It does feel warm although not sure how warm it used to be. I have raised it up on a couple of wooden blocks to improve airflow from underneath to see if that helps.
22-01-2012 4:48 PM
22-01-2012 4:59 PM
Its also definitely running cooler since I raised it up on the shelf it was sitting on.
22-01-2012 5:02 PM
22-01-2012 5:22 PM
22-01-2012 5:28 PM
22-01-2012 5:30 PM
is there any utility available that will be able to give me a clue as to what is causing the reboots?
22-01-2012 6:48 PM
I've never seen such a utility, unless you could set routerstats to run for extended periods. You would still have the problem of interpreting the results. I am on the verge of just buying a better router, unless this discussion leads to a solution.
22-01-2012 7:40 PM
Quote from: frank39 At risk of stating the obvious, you could just swap the routers over and leave the router to allocate the IP addresses. That will avoid any conflicts and test for restarts. If you then go back to the original router, the allocated IPs will still be there. I leave my router to allocate IPs and I have had probably more than ten devices attached, when everybody comes home.
I think my main aggro will be the devices reconnecting. I guess if I change the SSID and Key on the new router to that of the old then they should all be able to log on without manually re-entering everything - or is that just wishful thinking?
22-01-2012 7:46 PM
22-01-2012 7:47 PM
Quote from: PhyllisTyne I think my main aggro will be the devices reconnecting. I guess if I change the SSID and Key on the new router to that of the old then they should all be able to log on without manually re-entering everything - or is that just wishful thinking?
That will work fine,I have just done the same thing.
